87 sputtering
Old Sep 20, 2002 | 03:38 AM
david in germany's Avatar
Question 87 sputtering
ok i got my 87 4runner back from the local toyota dealer
after they did a timing chain replacement and put in a new clutch
and since then it will idle ok and sputter every few seconds. they had the engin out of the truck and everything seems to be hooked up correct but still the sputtering drives me nuts. i have replaced the plugs , cables and cap and rotor but still same thing but it is ok when the ac is on. what do i need to check?
David
Old Sep 20, 2002 | 04:08 AM
Toddski's Avatar
Hi there David.
Has the fuel filter been replaced?
My GMC Yukon had a hesitation at low speeds. I replaced the fuel filter and it ran great.
Also try a higher octane gas to see if that helps.
Old Sep 20, 2002 | 04:27 AM
sputtering
i have no loss of power and they did the filter with the timing chain. it is only at idle i notice the problem i checked the timing and it is text book on the money. i am going to try the higher octain but untill then i filled up with a fuel additive (injector cleaner)
David
Gutted91
Jan 3, 2020 09:48 AM
Marley2984
Dec 6, 2015 05:19 AM
Firefightersink15
Nov 23, 2015 10:32 PM
93RedKrawler
Sep 25, 2015 04:03 AM
Gutted91
Sep 17, 2015 05:44 PM
