4wd problems...
Old Jul 6, 2004 | 01:32 PM
ksig4runner's Avatar
Unhappy 4wd problems...
Last time i went out, my front differential would not engage and i have no front wheel drive at all. The 4wd selector shifts fine but i have no light go on and nothing seems to be engaging.Is this a problem that anyone has had??
Old Jul 6, 2004 | 01:41 PM
VolcomTacoma's Avatar
I'm guessing you have the ADD system, not manual locking hubs right? My 93 which had ADD, also had the 4wd light problem. It would flicker after using 4wd for a while or just not turn on at all, which caused the front diff not to engage. I ended up converting to manual hubs and defeating the ADD system(writeup here: http://www.4x4wire.com/toyota/tech/add/). The light would still act up, but at least my 4wd would work reliably now. I never found out what the problem was and still did it after all the vacuum components were removed, but guessing it was the switch in the front diff.
Old Jul 6, 2004 | 01:44 PM
mastacox's Avatar
My guess is you have a leak in the vacuum line that leads to your ADD system... It's pretty common even though I have never actually had this problem... You could try looking at the lines and see if they are in one piece.
http://www.off-road.com/toyota/tech/add/index.htm should help with checking the system out.
The little green 4WD light not turning on means the ADD is not engaging, most likely a vacuum malfunction.
Old Jul 6, 2004 | 04:16 PM
rpeAMP's Avatar
Also try driving for several minutes in 4Hi. When I first bought my 4Runner, the 4WD virtually hadn't ever been used, so it took about 5 miles to get it the light to stop flickering and for it to engage firmly.
Old Jul 6, 2004 | 04:18 PM
tombothetominator's Avatar
i 2nd the vaccum check!
kawazx636
Oct 6, 2021 03:03 PM
Daenerysdad
Oct 1, 2015 07:33 PM
tylermx71
Sep 29, 2015 08:49 PM
Cycles
Sep 29, 2015 06:37 AM
May-39
Sep 6, 2015 01:05 PM
