4wd light does not come on
Old Sep 28, 2003 | 09:27 AM
Unhappy 4wd light does not come on
Hi
I am going offroad later today and noticed that when I tested my 4wd the light in the dash did not come on. I read out possible vacuum hose problems on 2nd gens, is that the same for 3rd gen?
Is there an easy way to test whether the 4wd is working, I will need it this afternoon.
Carsten
Old Sep 28, 2003 | 09:30 AM
Reed23's Avatar
What year is your truck? When i had a '91 chevy I always had problems with the 4wd actuator making a good contact with its autolocking hubs. I eventually wound up splicing and soldering the wires together to get rid of that problem.
Reed
Old Sep 28, 2003 | 09:32 AM
it is a 99
Old Sep 28, 2003 | 09:43 AM
Reed23's Avatar
So then you do have autolocking hubs, the actuator should screw in somewhere on the front axle and should have two wires coming out of it. I would start by disconecting it and testing the voltage going to it. out of 4wd and then in 4wd and see if you get a current change and also try to clean up the contacts down there.
Old Sep 28, 2003 | 11:49 AM
RobT2k's Avatar
What about just driveing around a bit in 4wd then jack up the front and give it gas and see if the front wheel turns? Then start checking the other stuff.
edit: I guess you'd have to jack the back up also, otherwise the truck would take off on you. :pat:
Old Sep 28, 2003 | 01:16 PM
Reed23's Avatar
If you do it the jackstand way, I don't recommend it, just make sure that you don't have anything near it that you don't run over. That way if you get on the gas too much and the torque from your engine somehow manages to imbalance your truck enough you don't destroy something you still like or use.
Old Sep 29, 2003 | 08:23 AM
Cool all good
Hi
I took the runner to a dirt lot and after going forth and back between 2H and 4H the light went on. To check if 4wd was engaged I tried spinning all tires on the dirt and noticed skids from both front and back tires.
So I went offroad with RobT2K and co. (any pics yet Rob?). Lots of fun.
Thanks for the input, if the problems reoccur I will take a look at the wiring.
Carsten
mskalmus
May 28, 2017 07:51 AM
adammtb
Jul 27, 2015 11:57 AM
Athansinis
Jul 27, 2015 08:38 AM
ripp96
Jul 25, 2015 02:32 PM
TokyoD23
Jul 12, 2015 06:01 AM
