4.88s are in - my reaction.
Old Mar 16, 2005 | 06:50 PM
slyang1012's Avatar
Originally Posted by 86toyota
I did the same thing as you Sizzle. To be honest I wasn't that impressed also running the 4.88's. They only lasted a month(setup wrong) so I went with the 5.29's. That's were I noticed a difference. I perfer the 5.29's way over the 4.88's.
Well the 5.29's broke after 5 years, so I threw stock gears back in(4.10's) Holy ˟˟˟˟ was it a DOG after that. Can't wait to regear again.
Hey, how much were the 5.29's? and installation?
Old Mar 16, 2005 | 09:28 PM
Brendan's Avatar
ok, so i've had it up some steep hills, and there is more power, but not as much as I had anticipated from hearing other peoples reactions. i'm going to put a full tank of fuel in and see what sort of mileage difference it makes, but unless it's alot, i very possibly will be putting back the 4.10s
Old Mar 16, 2005 | 10:03 PM
Glenn's Avatar
What exactly did you anticipate? More power? Less power?
Old Mar 17, 2005 | 12:17 AM
deathrunner's Avatar
Did you have to slip first gear to get it rolling before? Were you able to use 5th gear before? I couldn't with 4cyl and 4.10's and 33's
now with 4.88's I can start without slipping the clutch and 5th gear is a staple in my driving funcition.
Old Mar 17, 2005 | 08:21 AM
  #25
Brendan's Avatar
DR: nope, never had to slip the clutch before. well maybe a tad if i was starting on a very steep hill. I used 5th all the time on the freeway before.
Glenn: I anticipated more acceleration - bottom end torque i guess.
Old Mar 17, 2005 | 09:56 AM
  #26
Glenn's Avatar
If you wanted more lower end grunt, then you should have gone with 5.29s. What you have done is stay close to stock gearing with your tire size increase/regear. That is why you don't notice a huge difference in performance. If you had gone with 5.29s, you would experience somewhat higher RPMs at highway speeds. The stock gearing is a compromise for all types of driving situations. Gearing specifically toward one end of your RPM band will have a negative effect on the other end.
Old Mar 17, 2005 | 10:07 AM
  #27
slyang1012's Avatar
.. yeah yeah yeah.. stupid question, but here goes.. to re gear, all you need is ring piston?
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WD1V
Old Mar 17, 2005 | 11:17 AM
  #28
Yamaha+Toyota=Fun's Avatar
I am going to be putting in my gears this weekend. I am not sure what gears I have in the truck right now. I currently have 33x12.5's and I can still use 5th gear. I have no door jam stickers or anything like that so I have no way of telling untill i pull the gears. Ill let you guys know how it turns out.
Old Mar 17, 2005 | 03:25 PM
  #29
Firetaco's Avatar
[QUOTE=slyang1012].. yeah yeah yeah.. stupid question, but here goes.. to re gear, all you need is ring piston?
if you mean ring and pinion,yes,,but if you have a 4wd,then you have to regear both front and rear diffs,,,and the install kits are nice since i was told that one of the pinion bearings is a booger to get off without destroying it,,,is that what you were looking for?? later
Ernie
Old Mar 17, 2005 | 04:40 PM
  #30
slyang1012's Avatar
[QUOTE=Firetaco]
Ernie
Well.. i came across this on ebay.. is this a good price for the ring and pinion?
http://cgi.ebay.com/ebaymotors/ws/e...sspagename=WD1V
Oh yeah.. mines only 2wd on 285s -V6 5speed
Old Mar 17, 2005 | 04:43 PM
  #31
dragr1's Avatar
[QUOTE=Firetaco]
Ernie
Almost a guarantee that you will destroy that bearing getting it off.
Old Mar 17, 2005 | 07:37 PM
  #32
Firetaco's Avatar
[QUOTE=slyang1012]
if this is the page you were refering to,then yes,$200 is around usual good deal price,,,******brett,is there any way to tell if this set is the bad richmond gears??***** if it is the bad gears,then you don't want them!! later
Ernie
Old Mar 17, 2005 | 08:49 PM
  #33
Del's Avatar
Del
So if I have this right... 5.29's will provide more low end power, but worse MPG right? How much worse, since I'm already down to 12mpg stock?
Old Mar 17, 2005 | 09:23 PM
  #34
slyang1012's Avatar
[QUOTE=Firetaco]
Ernie
is richmond a brand?.. in the description it says its Yukon gears... err i dunno im rambling again.
Old Mar 18, 2005 | 03:17 AM
  #35
dragr1's Avatar
[QUOTE=Firetaco]
Ernie
Can't tell from that pic if they're Richmond, and then there is no way to tell if they are the bad ones unless you try the bolts in hand.
Old Mar 18, 2005 | 05:15 PM
  #36
Firetaco's Avatar
QUOTE=slyang1012
is richmond a brand?.. in the description it says its Yukon gears... err i dunno im rambling again.[/QUOTE]
richmond is a brand/manufacturer,,yukon is a repacking company,,,they repack other manufacturer's products into their boxes,,,so there is no real way to tell which gear brand you have without close inspection of the set,,and the "bad" gears that i was refering to were not drilled/tapped properly making it impossible to use the ring gear. later
Ernie
Old Apr 14, 2005 | 10:36 PM
  #37
Brendan's Avatar
Went through a full tank of fuel and I got an extra 20-30 kilometers. Pretty disappointing. I'm pretty sure i'll be switching back and re-selling these 4.88s
Old Apr 14, 2005 | 11:00 PM
  #38
WSU4runner's Avatar
How much are you going to sell the 4.88s for? That is, if you decide to sell them
Old Apr 15, 2005 | 10:18 AM
  #39
Brendan's Avatar
$550 cdn. front and rears are both in carriers already. just need to be bolted up to the truck.
Old Apr 15, 2005 | 12:08 PM
  #40
MorphiasX's Avatar
If you decide to sell... and WSU doesnt get them, im interested in the 4.88's too...
