3rd member swaps?
Old Jan 5, 2003 | 02:02 PM
ROCKRUNNER's Avatar
3rd member swaps?
Ok heres the scenario. I welded up my V6 third quite some time ago and I want to change back. Its just too hard on tires. So my question is will a 4cyl housing bolt into a V6 housing? If so are the splines the same? and can I swap my V6 gears onto the 4cyl 3rd? I have a spare 4cyl 3rd from an 82 Toyota for my straight axle so instead of spending money on a new 3rd I was hoping to just swap the other one in. Thanks
Old Jan 5, 2003 | 02:53 PM
DarylD's Avatar
You can interchange the v6 3rd for the 4cyl third but it won't be as strong. Also if your 4cyl 3rd is an 82, the drive shaft flange is a different bolt pattern than the v6 3rd (smaller). You can't put v6 gears into a 4cyl housing, but you can put 4 cyl gears into a v6 with a ring gear spacer Hope this makes sence.Your best bet is to find a different carrier(the part you welded)I have one I can sell you . Daryl Ddouglas4909@aol.com
Old Jan 5, 2003 | 04:30 PM
ROCKRUNNER's Avatar
Thanks Daryl
Im interested in that carrier, How much do you want for it? I mailed you so reply here or mail me at futhermuqqer@yahoo.ca Thanks
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
93toyoguy
Aug 2, 2015 07:41 PM
