3rd member swaps?
3rd member swaps?
Ok heres the scenario. I welded up my V6 third quite some time ago and I want to change back. Its just too hard on tires. So my question is will a 4cyl housing bolt into a V6 housing? If so are the splines the same? and can I swap my V6 gears onto the 4cyl 3rd? I have a spare 4cyl 3rd from an 82 Toyota for my straight axle so instead of spending money on a new 3rd I was hoping to just swap the other one in. Thanks
You can interchange the v6 3rd for the 4cyl third but it won't be as strong. Also if your 4cyl 3rd is an 82, the drive shaft flange is a different bolt pattern than the v6 3rd (smaller). You can't put v6 gears into a 4cyl housing, but you can put 4 cyl gears into a v6 with a ring gear spacer
Hope this makes sence.Your best bet is to find a different carrier(the part you welded)I have one I can sell you . Daryl Ddouglas4909@aol.com
Thanks Daryl
Im interested in that carrier, How much do you want for it? I mailed you so reply here or mail me at futhermuqqer@yahoo.ca Thanks
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
