3rd Generation rear sag
Old Jul 30, 2005 | 03:35 PM
Citykid's Avatar
Anyone have this? My ride, 2001, shouldn't have this but I'd swear that it's getting lower in the rear.
Old Jul 30, 2005 | 03:55 PM
marko3xl3's Avatar
Shocks are failing.
Old Jul 30, 2005 | 04:59 PM
lee's Avatar
lee
in your 01, that is strange.
i had 70K or so on my springs before i swapped out to pp springs.
they didnt sag at all.
Old Jul 31, 2005 | 03:04 AM
Beartracker's Avatar
I have an 01 Tacoma with 73,000 and no sag at all and no problem with the shocks. They are just about as stiff as new. Maybe you have a leaf broken, I broke one last year. Sometimes you really have to look for it because it could be broke in the middle. Mike
Last edited by Beartracker; Jul 31, 2005 at 03:07 AM. Reason: Forgot to ad my miles
Old Jul 31, 2005 | 05:28 AM
JimmyK's Avatar
Just pop in a one inch spacer Im sure plenty of people here can point you in the right direction for a 1 inch spacer.
cheers
Old Jul 31, 2005 | 09:14 AM
Epic Ed's Avatar
Rear sag in a 3rd gen 4Runner is not normal. Tossing a spacer on top of a problemed situation would just mask the problem. As mentioned, get your shock and springs checked. If you've done a lot of heavy duty towing or load carrying that has caused premature wear, go with some after market improvements.
Ed
Old Feb 20, 2008 | 12:35 PM
stiven's Avatar
sag in back end
Will just putting some air shocks in the back help take out the sag in my 04 tacoma 4X4. I can't afford a lift right now, but want to lift the back end a little
Old Feb 20, 2008 | 12:53 PM
mpavolka's Avatar
They all sag eventually, I have 99' which came with the tallest springs and it was sagging til I replaced them. Best bet is to search all the different posts and find the best solution for you. Spacers will work for a quick fix but will destroy your springs in the long run. Shocks will not do anything unless they are adjustable air shocks. Best bet is to get some Performance Products (PP), Old Man Emu (OME), or Downey rear springs, new Toyota ones will fail again.
Old Feb 20, 2008 | 12:54 PM
gilby4runner's Avatar
I have an 02 sport and i am looking into the PP springs or the SS#2 kit. I tow a bass tracker boat and an 8 x10 trailer on occasion and i guess it has worn things a little quicker than i wanted. The rear shocks are worn (really bouncy)
Old Feb 20, 2008 | 12:56 PM
Godzilla's Avatar
The 01, and 02 are the lowrider years for the 3rd generation 4runner due to the rear coils.
So to answer your question: yes people have this.
Old Feb 20, 2008 | 12:57 PM
sorry to hyjack but if i went with the PP 1 inch springs for the 99 would it give me 2 more inches of lift?
Old Feb 20, 2008 | 01:05 PM
mpavolka's Avatar
I have never owned the PP springs, but it all depends on how low your car is now. I put Downey 2 " ones on my 99' originally and it sat 1/2" taller in the rear. I would guess and anybody else is free to correct me but the PP springs are more of a rear leveling lift than actual lift. I think PP advertises 1" over stock. And 99's are already taller so I would imagine it would sit fairly level. I have some pictures I could PM you later of what my 99 looked like with the Downeys.
Old Feb 20, 2008 | 01:11 PM
The PP springs are supposed to lift my truck 1". If i went with the 99 springs then it would sit higher than if i went with the 02 springs. So i should get at least 2 inches of lift... I just wish there was a better option for 4runners that tow a lot.
Old Feb 20, 2008 | 01:16 PM
cackalak han's Avatar
Holy 3 year old thread...
gilby - Are you wanting a lift at the same time or do you just want a more heavy duty spring?
Old Feb 20, 2008 | 01:22 PM
you could try airlift bags also.
Old Feb 20, 2008 | 01:29 PM
I figured i would just go ahead and change out the front springs also. I have to replace all 4 shocks. Just looking into my options.
Old Feb 20, 2008 | 02:52 PM
MTL_4runner's Avatar
Guys, he said he's got a Tacoma......that's got leaf springs in the rear.
stiven, you may be able to rig up a cheap airbag setup but some new Deaver springs from Sonoran Steel would work alot better.
Old Feb 20, 2008 | 04:05 PM
mpavolka's Avatar
Yea but I think the rest of the guys were talking about 4Runners... this forums's all mest up! Like he said though he can put air shocks on it, not the best route but that's what he said he wants, an add a leaf might be cheaper. As for the 4Runners they need air bags or springs.
Old Feb 21, 2008 | 06:33 AM
edzo's Avatar
99 4runner, 140,000 miles, no sag. and I haul crap.
some days I thought it was sagging, then realized I had a cord
of wood stuffed in it incl the front pass seat
it doesn't take much weight at all to make it sag a little,
but empty or with 50lbs in it, sag doesn't happen on 3rd gen
check yer rear swaybar bushings and links. shocks don't do anything for
sag unless they are the wrong size, it is all in the coil springs.
Old Feb 21, 2008 | 06:45 AM
dirtoyboy's Avatar
Originally Posted by marko3xl3
Shocks are failing.
How does that work exactly?
