3rd Gen TPS adjustment?
Old Oct 24, 2007 | 09:19 PM
Crazychopstick's Avatar
I haven't had a chance yet, but I've been meaning to take off the throttle body for a thorough cleaning and also clean out the IAC on my 3.4 (5vz).
I had a few questions before I start:
1)So I assume that you unbolt the 4 main bolts on the TB and the whole assembly slides out, is there any thing else besides the throttle cables that I need to disconnect first?
2)After reinstalling the TB, is there a need ro readjust the throttle position sensor (TPS)? Is it even possible on 3rd gens?
3)How much ft/lbs. should I tighten the throttle body to the intake plenum?
Thanks in advance.
Old Oct 25, 2007 | 04:53 AM
MTL_4runner's Avatar
Don't forget the vacuum and coolant hoses on the TB too.
There are also 2 electrical connectors (IAC and TPS).
No, there's no adjustment.
The spec is 13 ft-lbs, but just hand tight will be fine.
Thanks in advance.
Answers in red.
Old Oct 25, 2007 | 07:15 AM
BajaRunner's Avatar
Yeah, there are two hoses beneath the IAC that are sort of a pain to access. That was the hardest part in my opinion.
You'll be absolutely stoked with the results though. It made a HUGE difference after cleaning the IAC.
Old Oct 25, 2007 | 07:13 PM
Thanks MTL, the TPS didn't look adjustable, but I wasn't sure.
I'll post up results when I do it.
smthwsn357
May 1, 2024 07:28 AM
Blamalam
Mar 12, 2022 07:34 AM
wafoogalla
Nov 2, 2016 11:02 AM
bighaydn
Aug 4, 2015 07:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
