3rd gen tires
Old Oct 12, 2004 | 08:03 PM
idrivea4runner's Avatar
3rd gen tires
my 97 sr5 needs new tires. what's the largest size tire that will fit on a 2wd 3rd gen without rubbing?
Old Oct 13, 2004 | 04:03 AM
jacksonpt's Avatar
Senior Member
Do you have any lift? 15" or 16" wheels?
If not... a 31" tire is probably about it. I ran 32/11.5-15s on my rig with a 3" lift and rubbed in the back at times. If you are on a 16" rim, you might be able to get away with a 32/10.5... is that a 275???
Old Oct 14, 2004 | 09:18 PM
i have 16 inch wheels
i have 16 inch wheels...i want the biggest tires that will fit with no modifications
Old Oct 15, 2004 | 03:26 AM
4RunnerFever's Avatar
265/75-16. Roughly one size up from stock. You'll take a milage hit however, as these will be heavier.
Welcome to the forum.
Old Oct 15, 2004 | 05:54 AM
travelinman's Avatar
Yep, 265/75-16. I have that size on my '99 4runner and I have no problems. In fact, I love the look; it's a bit taller and beefier looking (I have the BFG A/T ko). One thing to keep in mind besides the mileage thing is that your speedometer and odometer will read inaccurately. You'll actually be going faster than the speedo says, but not by much. There are some conversion tables floating around the web and on this forum, I believe, to check that out.
Here's a good site for conversions etc... http://www.4lo.com/4LoCalc.htm
Good luck!
Old Oct 15, 2004 | 06:02 AM
waskillywabbit's Avatar
Talking Largest tire on stock 3rd gen
You can fit a 315/75/16 on there no problem.
BushPig
Oct 29, 2022 06:26 AM
Jun 1, 2021 01:51 PM
djpg2000
Nov 11, 2020 04:56 AM
jerusry
Oct 19, 2015 05:28 PM
93toyoguy
Aug 2, 2015 07:41 PM
