3rd gen Tailights
Old Jul 29, 2003 | 07:03 AM
Murph's Avatar
3rd gen Tailights
My driver's side tailight is out again. Seems to be some sort of loose connection as bulb is good. Brakelight works fine. Since I've seen this on at least a dozen other 4 Runners on the road, almost always on the same side, hoping someone's diagnosed this problem already. Any thoughts?
Old Jul 29, 2003 | 07:48 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
I've had this problem myself. The first time I assumed it was the bulb and replaced it. It worked fine for a day or 2, then went out again. Suspicious, I checked the bulb and found that it was good. I sprayed contact cleaner in the socket, wiped the contacts down and put the same bulb in. The problem has not resurfaced in over 9 months.
LittleUgly
15
Jan 2, 2020 01:30 PM
Flightguy
Oct 2, 2015 05:34 PM
voiddweller
Oct 2, 2015 07:47 AM
Rickstwowheels
Sep 29, 2015 02:23 PM
charlie_fong
Sep 27, 2015 10:06 PM
