3rd Gen control arm bushing kit?
Old Aug 9, 2005 | 04:36 AM
toy_tek's Avatar
Is there some kind of replacement bushing kit for my 97 4R? I want to replace all the control arm bushings as well as the steering rack mount bushings. Are there any others I should do at the same time? What type are the best? Where can I get them?
Old Aug 9, 2005 | 05:11 AM
ecchamberlin's Avatar
I have used the Energy Suspension bushing kits and really liked them. I did the sway bar ends, sway bar mounts, bump stops and the steering rack bushings. All are easy to do and are polyeurethane so they will last a lot longer than the stock rubber ones. Most auto parts stores can order any kit you need. Daystar also makes them and are really the same as the Energies. I just checked the Performance Products web site and they have the Daystars. You'll have to call though because they are not showing for the 4Runners but I'd bet they have them. I know for sure that 4Wheel Parts has Energy Suspensions.
Your avatar totally rocks. I am a huge Eddie VanHalen fan and that was the guitar that made it all happen.
Old Aug 9, 2005 | 05:22 AM
rimpainter.com's Avatar
I would not rate the steering rack bushings as easy. I have done two sets on two different 4Runners, and both times it has been a major pain. The tolerences are so tight that getting everything to fit becomes an experience.
Yes, it is technically easy - but actually getting them in place and everything bolted down is a major ordeal. I turn a pretty good wrench and the last set took me about 3 hours. Also, some 4Runners may have been previously aligned with the old rack bushings in place, causing your steering wheel to be off-center after the new poly bushings are installed. So an alignment is sometimes necessary.
Old Aug 9, 2005 | 06:12 AM
toy_tek's Avatar
Thanks for the info guys. I'll look into a kit. I forgot about the swaybar, but I'd like to change them all.
Cool, thanks man. I built that one this past spring. Turned out much better than I thought it might! another pic
Old Aug 9, 2005 | 11:35 AM
MTL_4runner's Avatar
Ditto on this....serious PITA!
......but was well worth it!
Old Aug 10, 2005 | 02:03 PM
2001Millrunner's Avatar
what are the differences if you guys dont mind asking? My sway bar sqeaks sometimes and my steering feels lose now. Would this remedy the situation?
Old Aug 10, 2005 | 02:19 PM
I can speak for the steering rack: yes, it firms up the steering feel quite a bit. It's a great mod if you have the patience and tools for it.
I have endlink poly on my front sway and I didn't really notice a difference.
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
andrewtexas123
Jul 23, 2015 11:22 AM
ksmudrunner99
Jul 21, 2015 05:33 AM
1994toyota
Jul 17, 2015 03:03 AM
