3rd Gen 5-speed VERY hard to shift???
Old Nov 14, 2012 | 05:58 AM
mschein1's Avatar
I think you might need a new clutch master cylinder. I had that identical problem in my old 94. There are seals in there and sounds like one may have gave on you.
Old Nov 14, 2012 | 09:07 AM
UNR.Grad's Avatar
I checked the clutch master cylinder and it's totally empty now. The pedal is stuck on the floor.
I ordered a new master cylinder and slave, I'm not sure where the leak is but I figured I'd replace both.
Any tips on replacing them, it's pretty much just unbolt both, rebolt the new ones on and then bleed the system? Do I need to bench bleed the master first?
Thanks
Old Nov 14, 2012 | 11:16 AM
mschein1's Avatar
I would bench bleed it first. But yeah just unbolt and bolt in the new ones. If you are doing this by yourself. I have had luck gravity bleeding them after it is installed. Just make sure you keep fluid in the master.
smthwsn357
May 1, 2024 07:28 AM
Liadrin
Apr 25, 2022 02:54 PM
mskalmus
May 28, 2017 07:51 AM
crashburnoveride
Jul 10, 2015 06:39 AM
coryc85
Jul 6, 2015 04:07 AM
