3rd gen. 1996-2002 4RUNNER Owners Poll: Does your cruise control work???
#44
Year - 1997
Model - SR5 4wd
Cruise Control Use - Multiple times daily
Miles - 211k
Mine didn't seem to work when I bought it, but then I figured out the clutch pedal wasn't always fully returning, leaving the switch for the cruise open and effectively disabling it. I simply pull the pedal out with my toe if it doesn't spring all the way out, and it works every time. Just a thought...
Model - SR5 4wd
Miles - 211k
#48
it works well enough... up hills to maintain speed it makes the tranny shift a little hard, and it will stay at high rpms for a bit too long (30 ish secconnds) otherwise its great
98 4wd sr5
140,xxx miles
98 4wd sr5
140,xxx miles
#54
Both are working fine.
Year - 1999
Model - Base 2WD
Cruise Control Use - Frequently, several times daily
Miles - 150k
Year - 1999 #2
Model - SR5 4WD
Cruise Control Use - Several times weekly
Miles - 150k
Year - 1999
Model - Base 2WD
Miles - 150k
Year - 1999 #2
Model - SR5 4WD
Miles - 150k
#55
Works like it's suppose to..
Year - 1999
Model - Limited 4wd
Cruise Control Use - Limited, 2x/month
Miles - 140k+
I've only had it for 6 months so as for the previous owner(s) there is no tellin' how much the CC was used.
Year - 1999
Model - Limited 4wd
Miles - 140k+
#60
Works Great
1998 SR5 V6
171 000 kms on original engine
I too find that the Cruise downshifts too much on hills, but I hear that is normal for these trucks. I researched the truck before I bought it, and Lemon Aid said that it was common.
I don't know how to fix your problem though, good luck at fixing it....
1998 SR5 V6
