315/75/16 Maxxis Bighorns on my 98 4Runner
Old Jan 5, 2009 | 06:24 PM
  #41
BIGMIKES~98RUNNER's Avatar
thank you both for the great pics...rigs look great and the info on the body lifts. i am looking for the company that makes the 1.5" body lift or may just go with the 2". idk we will see.
Old Jan 5, 2009 | 07:29 PM
  #42
BajaRunner's Avatar
Bigmike: You are really getting 250-270 a tank!? How big is your tank?
I get about 200-220 per tank!? Whats the matter here...
Old Jan 5, 2009 | 07:38 PM
  #43
wyorunner's Avatar
4crawler.com does custom size BLs, check his sit out its got a lot of information on body lifts. he is cheap priced but its great quality product, i have a 1 inch from him, wish i would have got 1.5 or 2 so i can get 315s, but im probably going to get 315 any way.
Old Jan 5, 2009 | 08:12 PM
  #44
xcmountain80's Avatar
Why wouldn't you be able to run 315's w/o more than a 1"? If you truly have 3" in addition to the 1" BL you should be go to go. I', using the SS lift w 1" Wabfab BL and wanted to clear 35's but run 33's for the optimal clearance.
Aaron
Old Jan 5, 2009 | 11:55 PM
  #45
wyorunner's Avatar
it was about a 6 month used kit, so im guessing i have approx 2.5 - 3". but with a 1" body lift i should be able to get 315s in there no problem. itll just be reason to get a better lift, to save the tires. and im going with Nitto as well, just not sure if i wanna go with 295 or 315. i have the stock sport rims and im afraid they will be too skinny for the 315s. anybody know the width of the rim.
Old Jan 6, 2009 | 04:46 AM
  #46
Should be stamped on the inside of the rim or the out side for that matter.
Aaron
Old Jan 6, 2009 | 06:16 AM
  #47
wyorunner's Avatar
ya i thought it was but im in iraq or else i wouldnt have asked. thanks
Old Jan 6, 2009 | 08:47 AM
  #48
Iraq huh? Well that does pose a problem.
Aaron
Old Jan 6, 2009 | 06:00 PM
  #49
wyorunner's Avatar
unfortunatly, but hey, it provides me with plenty of money to buy all kinds of parts for my 4runner. in march when i get home im going to do a "build up" for everything ive got, which, is a pretty fair amount. and tires is going to be included.
Old Jan 6, 2009 | 07:30 PM
  #50
i could not belive it neither untill i got the garmin...i dont think it could be wrong. right when the fuel light comes on im at 225 on the gps..200 on the speedo trip. thats with both highway and city with an easy pedal. i can honestly say i average 240 no problem.
maybe its the higher lift that is causing more drag. also this truck has never been abused untill i can do it....bone stock with all service records when i got it.
when i fill up i can never get more then 16g in the tank..so im guessing our tanks are 17-18...i dont even know what the owners munual says...never looked. i am also running stock gears..have to find out what size, but on the highway i can run 75 at 2400 rpm
Old Jan 6, 2009 | 07:36 PM
  #51
Aaron
you will also need at least a 1" wheel spacer with a stock wheel to clear the uca.
i just clear the uca (1/4") with a 4"bs wheel and the 315's
Old Jan 6, 2009 | 07:40 PM
  #52
i will, thank you for the info.
Old Jan 6, 2009 | 11:57 PM
  #53
wyorunner's Avatar
ya i didnt even think of that, thanks for the info.
Old Jan 23, 2009 | 03:47 PM
  #54
LC coils installed and Tokico longs....
just need to install the trim spacer up front to get a little more lift and try to even it out...
Old Jan 24, 2009 | 01:42 PM
  #55
emptypockets's Avatar
The LC's have lifted it perfectly! How was the install for you?
Old Jan 24, 2009 | 02:41 PM
  #56
simple...with a sawzall and air chisel punch. 5 min's and the shocks were out. disconnect the sway bar, remove tires, place jack stands under the frame and lower the rear end. removed old coils / spacers and installed the LC coils. then install new shocks...installing the top bolt is no problem when new and with the right swivel socket.
the complete tear down and install was about 1.5-2 hours max.
Old Jan 24, 2009 | 03:15 PM
  #57
FJHammerHead's Avatar
I really love the look of your 4runner. I could never keep my black cars that clean...
Old Jan 24, 2009 | 08:00 PM
  #58
WOw I'm getting 250-270 in FL and in AL, GA, TN 260-298 was my best. avg. speed 70mph some city. Typical around town is 250-260 before the light comes on. I'm geared with 4.56's. Something fishy goin on here. Although I would be willing to test run someones 315's if they like to verify the #'s
Aaron
Old Jan 24, 2009 | 08:55 PM
  #59
the_kernel114's Avatar
hey I'm new to yt and was just wondering did the soft 8's fit without any handy work?
Old Jan 24, 2009 | 09:11 PM
  #60
I doubt it!
Aaron
