305/70-16 vs 285/75-16 on a 3rd gen
Old Jun 25, 2005 | 02:06 PM
  #61
RobT2k's Avatar
Originally Posted by bamachem
well, if you go w/ ats, then you run into other issues like overextending the CV joints on a full droop and then blowing them out. if you want to modify the upper a-arms, then do what steve schaefer did. there should be some good info on his site...
I've had them for 2 years and numerous wheeling trips and that has never happened (knock on wood)
I meant: Since I already have ATS arms would I run into the rubbing issues and require the extra backspacing?
Old Nov 15, 2005 | 08:37 PM
  #62
964runner's Avatar
If i run a wheel spacer with my stock rim will i run into trouble with a 305/70/16 given i have a proper lift? any recomendation on the size of the spacer thanks
Old Nov 15, 2005 | 10:16 PM
  #63
northfacer581's Avatar
if you have the proper lift, rubbing will be minimal.
Old Nov 15, 2005 | 10:21 PM
  #64
garrett1478's Avatar
hes talking about on the a-arms.
andy has 16x8, 4.5 BS. you've got 16x7, stock BS, whatever that is. do the math to figure out what size space you need. check roger brown's site for wheel size math.
Old Nov 15, 2005 | 10:25 PM
  #65
964runner's Avatar
but their should be no problem with the rim actually holding the tire right? Can you ever go too large with your spacer, i was thinking of just ordering a 2"
Old Nov 15, 2005 | 10:55 PM
  #66
no, fink has a thread about 285s and 305s on stock wheels, you'll be fine.
i dont know anything about wheel spacers.
Old Nov 16, 2005 | 03:53 AM
  #67
bamachem's Avatar
on a 16x7 i would say to stick w/ a 285. it's a tight fit on a 7" wide wheel and it will rub w/o spacers or new upper a-arms.
a 305 is right at an inch wider, making them "bubble" out another 1/2" on either side of your 7" wide wheel.
they fit very nicely on a 8" wide wheel. the extra 1" makes a big difference.
Old Nov 16, 2005 | 05:26 PM
  #68
Albuquerque Jim's Avatar
That's what she said...
LittleUgly
15
Jan 2, 2020 01:30 PM
Flightguy
Oct 2, 2015 05:34 PM
voiddweller
Oct 2, 2015 07:47 AM
Rickstwowheels
Sep 29, 2015 02:23 PM
charlie_fong
Sep 27, 2015 10:06 PM
