3.slow fuel problem NOW !!!!!!!!!!!!!!
Old Dec 12, 2003 | 06:25 PM
NOW I HAVE A FUEL INJECTOR PROBLEM
should i just shot this thing?
it is leaking around the front two on the drives side
what do i need to do GOD PLEASE HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
and it will not start when hot now i can't believe it i fix one thing and another breaks shhhhhh it may hear me................................................ .................................................. ....................................
really guys what the hell? i'm real scared to drive it this way it may catch a fire wait...........it will not start when it gets hot never mind on that
duane
Old Dec 13, 2003 | 04:23 PM
hello out there is there anyone at home?
i really need your help here or tell me whrere to look for help
duane :
Old Dec 13, 2003 | 04:42 PM
phorunninduke's Avatar
if they are leaky tighten them. you never know simple things somtimes work the best.
Old Dec 13, 2003 | 04:44 PM
how do you tighten them plaese do tell
duane
Old Dec 13, 2003 | 05:49 PM
amusement's Avatar
Leaky injectors can be I sign that the seal is broken around the injector. If you have a cold start injector and it starts when its cold it makes sense. YOU AREN'T GETTING ENOUGH FUEL IN THE ENGINE WHEN ITS WARM.
I don't know the mileage but, I would guess just replacing the seal. Injectors pull out. GET A MANUAL and do a little research it all will make sense.
Old Dec 13, 2003 | 05:54 PM
thanks man i have 143k miles and stuff justs keeps breaking on this thing
it looks like its leaking around the gasket on the manafold and injecters where would i find the cold injecter?
and where can i buy a factory shop/service manual? i've searched the web and ebay but nothing i'll even would buy a c.d. rom type
thanks man
duane
Old Dec 13, 2003 | 06:01 PM
amusement's Avatar
EBay is a good place to start looking for a Toyota service manual.
Don't worry about the cold start injector. You know its working because you can start the truck when the engine is cold.
When the engine is warm the cold start injector doesn't need to work.
Most Toyota's last hundreds of thousands miles. The ones that don't make it have had poor or no maintenance, been under water, or just plain abused.
Old Dec 13, 2003 | 06:07 PM
Invest in a manual man. A haynes can be your best friend. It will solve 90% of all problems, or at least let you know whats up so you will not get rapped at the mechanics.
If your injectors are leaky, then not enough gas is getting to the chamber to combust. I am looking in the haynes right this moment. It is fairly simple, but too much to type.
basically....
if it is leaking at the rail there is a delivery pip, grommet ( O ring ) and the injector. If the injector is not on straight or the o ring is bad. Bingo you could probably reach and twist the injectors around a bit and tell if its lined up allright. pull it off and check out the o ring. just go to the hardware or auto place and grab new o-rings. ( new injectors might help generaly too, if you have an ohmeter you should check them too ) You might also wana check fuel pressure, it might be too high. But i bet its just an o ring.
Old Dec 13, 2003 | 06:08 PM
i searched the ebay site and nothing for the 89 4runners any other sites
yeah i know about toyota's i put 200k on a 95 tacoma 4x4 3.4 auto ext cab nothing wrong with the truck but the bed was beat up pretty badly and traded it in man i miss that truck i never and i mean NEVER EVER NEVER let me down started every time
damn good truck what a fool i was to get out of it everything worked too well it was i bone stock truck base model with the v6 and auto extra thats it
duane
i only wished i could go back and do it again i would NEVER ever gotting rid of it
Old Dec 13, 2003 | 06:23 PM
amusement's Avatar
Here are two manuals from Ebay:
Manual 2
Manual 2
Haynes also makes manuals covering fuel injection, computer management systems and emissions.
good luck!
Old Dec 13, 2003 | 06:27 PM
i really don't want the haynes manual i would like the factory shop manual if it is for sell this what i couldn't find
thanks \duane
Old Dec 13, 2003 | 06:33 PM
not to be too mean, but the haynes would be a good place for you to start. Ive gotten the impression your relativly new to auto work. The factory manual is great, but the haynes is like 14 bucks and will cover anything a shade tree mechanic would really need, it also is easier to understand. Plus those factory manuals are around 90bucks.
Old Dec 13, 2003 | 06:36 PM
hey thanks that is mean
just kidding yes i know they are around 100 buck but i want one and willing to paty the money for it and i have the haynes and don't like it the chiltons is a lot a better i know the factory would be ALOT better
duane
Old Dec 14, 2003 | 07:42 AM
well i just went outside i tried to start the 4 runner and it fired right up and it's pretty cold here in north alabama around 35 well that's cold enough for me i hate the cold any who i guess that is what's wrong the injecters or o rings i real hope thats my problem
duane
Old Dec 16, 2003 | 06:46 AM
williemon's Avatar
It is a pain sometimes to stop the leaking. My mechanic had a heck of a time and they claimed that they DID use new groments and o rings.
Old Dec 16, 2003 | 07:02 AM
MTL_4runner's Avatar
Try the new o-rings (remember to lubricate them with gas before assembly) to see if that fixes it. If it is still leaking wrap a tiny piece of teflon around the ring land (make sure the teflon is only in the ring land not around anything beyond that), then slip the o-ring over it. That should provide a bit more o-ring pressure to seal the leak. If it still leaks then you may need to replace the injector or the fuel rail depending on which is corroded or worn.
Flying91
45
Apr 11, 2024 04:39 PM
jbv808
Aug 6, 2021 04:47 PM
Sleaker
Aug 26, 2020 06:03 AM
Colington
Mar 8, 2020 09:51 AM
Eggslinger
Jun 8, 2019 03:32 PM
