3.4L Intake Manifold & Antenna Help!
Old Jul 21, 2004 | 09:45 PM
terrytcl's Avatar
Unhappy 3.4L Intake Manifold & Antenna Help!
Looks like I'm getting my Supercharger back from Magnuson before the weekend.
I've got a pair of new intake manifold gaskets and would like to replace the existing ones. I figure I would clean up the intake manifold of all of the oil deposits too. Does anyone have the torque and tightening sequences for the 3.4L intake manifold? It would help me a lot!
Also, I'm trying to replace the antenna on my 4runner. I was able to remove it from the fender, but now I can't find the other end where I can disconnect the cable. It goes behind the fender and disappears somewhere in the engine bay. For the life of me, I can't find where it's disappearing to.
Has anyone replaced their stock antenna? I believe my 4runner came from the factory with the power model, but for some reason, the prior owner replaced the power one with a cheezy pep boys non-power model. I'm trying to put a power one back in. Any help is greatly appreciated!
Old Jul 22, 2004 | 08:58 AM
terrytcl's Avatar
anyone?
Old Jul 22, 2004 | 09:02 AM
rimpainter.com's Avatar
Check out the tech section regarding the antenna. Bob has a good write-up.
Old Jul 22, 2004 | 09:44 AM
SLC Punk's Avatar
The antenna goes through the fender and into the cab. You will need to take out your glove box and stereo. The you can follow the wire and take it out.
For the torque spece pm or email Gadget.
Old Jul 22, 2004 | 06:17 PM
FattyCBR's Avatar
For torque numbers are you asking about the long ones holding the SC to the plenum? If so they're 12 ft/lbs, I've never used any particular order with them, just make sure you work them tighter in several stages.
Marsheen
Feb 17, 2016 12:29 PM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
shalom
Sep 8, 2015 10:02 PM
AkitaDog
Sep 3, 2015 09:01 PM
ksmudrunner99
Aug 7, 2015 06:46 PM
