3.4 swap 02 sensor troubles
Old Mar 29, 2014 | 01:06 PM
TheDurk's Avatar
Originally Posted by biopepper
Yeah from what I can tell I'm pretty sure he got the wiring all set last time I might as well just solder em together and see what happens. I'm using denso 234-9003. I'm a go solder them and drive it around for a bit see if the codes pop back up I'll let ya know what happens thanks again.
Good. Exact same sensor I use in mine. Good luck. If you have a real scanner, success is when you get into closed loop operation. A scanner will tell you that, a code reader will (usually) not.
Old Mar 29, 2014 | 04:47 PM
biopepper's Avatar
Ok so after ecu reset the only codes were p0500 (I don't have a speedo) and P0141 (haven't installed rear 02 incase I needa return it). I then drove it to my buddies about 15-20 minutes away and the p0171 lean code popped up. After driving it home however now I got the pending p1130. So I guess my next step is going to be to try and fix the exhaust leak and get my buddy over here with his scanner.
Flying91
45
Apr 11, 2024 04:39 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
94whiterunner
Jul 12, 2015 07:15 PM
wilbertd
Jul 6, 2015 07:39 AM
