3.0 turbo 4runner on ebay
Old May 5, 2005 | 08:00 AM
westy44runner's Avatar
Originally Posted by DeathCougar
la, ah-di dah. Its still a crappy motor that cant really handle boost, has head gasket issues, no power, no torque, etc etc.
NO TORQUE?? isnt that what the 3.0 is known for...
I own both a 3.0 4runner and a 22r modified P/U and there is no comparison to the torque between the two...I've driven many 22RE's and even those cant compare in the torque category...the 3.0 isnt any GREAT motor but its a hell of alot more reliable and will outlast any domestic motor
Old May 5, 2005 | 08:59 AM
Bumpin' Yota's Avatar
I dunno I'd still take a LS1 with a 150 wet shot over my 3vze anyday!! LOL
Old May 9, 2005 | 04:41 PM
reggiegrip's Avatar
Question
i really want to do that to my 3.0. Anyone have any suggestions on what turbo to use? I looked up the one that was used in the 3.0 on the ebay auction, and i found one for a really good price, but are there any others that are better? Also, what other parts do you need except for the turbo kit? Any/all help will be really appreciated.
Old May 9, 2005 | 07:43 PM
reggiegrip's Avatar
bump..
Old May 9, 2005 | 11:37 PM
  #25
AxleIke's Avatar
22r's had...timing chains. Which you really can't compare to, since you should replace a timing chain just the same as you replace a timing belt on the 3VZ...its called mantinence.
WHAT?!? If you have a timing chain guide problem, then yes, you should replace it. Other wise, they last a LONG LONG time. No way you should replace them as often as you replace a timing belt. In fact, most times they last longer than the engine, mine did.
The 22re, while a nice engine, is slow, underpowered, and has no torque. My 90 and some change horsepower is pretty sad. New gearing helps it, but unless you've got it geared really low, you'll still have it revved up when everyone else is idling over the rocks.
Old May 10, 2005 | 12:59 AM
  #26
DudeBud's Avatar
Originally Posted by DMG
You talk a lot of ลลลล. Would you like to hook up rear bumpers and pull against my weak 230k 3.0?
bring it
Old May 10, 2005 | 02:23 AM
  #27
DMG's Avatar
DMG
Originally Posted by DudeBud
bring it
Ok. First we need a really long chain because you are in WA and I am in PA.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
Roger Borba II
Jul 9, 2015 05:05 PM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
