2nd generation clutch problem. 90 3.0 with manual
Old May 24, 2004 | 01:46 PM
AbramHart's Avatar
Here is my problem.
I have a 1990 Toyota 3.0 with a manual. It has a Centerforce dual friction in it with around 15000 miles on it. New pilot and throughout bearing if it matters. When you crank it the clutch is firm and has no problems. If you drive it for 15 minutes or so the clutch starts to get soft. In other words you push it and it is almost all the way to the floor before it works properly. If I take it out of gear and pump the pedal for 1 minute or so it is firm again. The clutch is not burning and it is grabing perfect. I know you are thinking check the fluid dummy. I did and the fluid is good. What could be causing this problem?
Old May 24, 2004 | 03:01 PM
AverysDad's Avatar
you either have some air in the lines , or a leaky clutch master cylinder
Old May 24, 2004 | 05:34 PM
mxracer0486's Avatar
I would bleed your lines at the slave cylinder....
Old May 24, 2004 | 05:51 PM
Yoter's Avatar
Guest
Bleed it then bleed it again until you get tired of bleeding it. They seem to sometimes wanna be stubborn. My buddy recently put the same clutch in and we need to bleed it being he was whining the other day that it needs to be bled AGAIN. Hope you get er done!
Old May 24, 2004 | 07:32 PM
Fahrenheit 451's Avatar
This could raise a question I have been interested in for some time now. Assuming you went with a heavier duty pressure plate at the same time, I have wondered about the stock master/slave cylinders' ability to handle the increased force required to make a heavier duty pressure plate work. Surely the increased tension in the "fingers" of the pressure plate would put more stress on the cylinders??
If so, it would be even more of an effect on old parts and likely result in pushing fluid past the piston and loss of hydraulic pressure.
I know when people go with bigger brake systems they go with bigger brake master cylinders. Why is the same not considered with heavier duty clutches? Granted, the amount fluid volume is unchanged unlike in brakes systems changes where there is an increased fluid volume, but maybe bigger pistons could push the fluid with less strain on the cylinders.
Who am I kidding....I don't know. Anybody have the 411 on this one?
Old May 24, 2004 | 07:37 PM
86toyota's Avatar
I put the CF dual frition clutch in 7 yrs ago and have had "zero " problems with my stock master or slave cylinder.
Old May 25, 2004 | 04:18 AM
Yoter's Avatar
Guest
I think your on to something. Sounds like some quality logics there. Seriously. IMO
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
tobylab
Jan 18, 2016 07:06 PM
rushw
Jul 18, 2015 01:46 PM
the1998sr5
Jul 16, 2015 06:20 AM
tobylab
Jul 12, 2015 12:53 PM
