2nd Gen Radiator Replacement
Old Oct 23, 2002 | 07:07 AM
Memphis4X4's Avatar
Well, my '91 Runner's Radiator needs replacing....at least I think it does. I noticed tiny pin hole leaks (4 of them) across the top of the original radiator that are ooozing, crusty, dried Toyota Red coolant. With 155K miles on the clock, it appears that the radiator is finally going out. Do any of you have suggestions regarding replacement vs repair? Someone told me to take my original radiator out and have it repaired because the Toyota original is better than a unit bought from a radiator shop. The local shops want $154 for a new non-Toyota radiator. Also, I noticed that the one in the truck now has foam around the top of the original radiator that appears to be either an insulator or vibration dampening or to plug up the gap so air is directed through the radiator rather than around. It looks fragile and wouldn't survive being pulled off of the old radiator and put on the new. Any idea what that costs? Anything else I need to know?
Thanks,
David
Old Oct 23, 2002 | 08:08 AM
95_4X4Runner's Avatar
Good price
My Radiator was leaking also. I've tried having them repaired in the past, to me, it's not worth it. The best price I found for them was $125 w/shipping @ http://www.911radiators.com
Old Oct 23, 2002 | 09:33 AM
914runner's Avatar
i got mine from napa for about $120 i think?
hope this helps.
Old Oct 24, 2002 | 06:57 AM
Memphis4X4's Avatar
Thanks guys. Did you just replace the radiator or did you have to replace the foam "gasket" that goes around the top of the radiator where it rests against the engine compartment frame?
David
Old Oct 24, 2002 | 08:07 AM
Highland Runner's Avatar
That foam can be gotten just about anywhere that has hardware (Wal-Mart, Lowes, Home Depot etc). Its just foam weather stripping and comes in many sizes. Cost is only $3-4 a roll
Old Oct 25, 2002 | 10:58 AM
vlibo's Avatar
I'm having the same problem. I had tried to use soder to fix the crack, but to no avail. The radiator shop here said this is a common problem with toy trucks and runners. they said for $90 bucks they would remove the top part. core and flush the radiator and weld on a new top and pressure test it. I have to remove and deliver the Radiator. I'm still trying to find time to do it mine has been leaking for over a year. More of a pain in the a55 then a really problem.
Vince
Old Oct 25, 2002 | 12:33 PM
Memphis4X4's Avatar
Vince: Thanks for the info. A guy in my office has a '89 SR-5 V6 4x4 (same motor as ours) and he had the same problem with pin hole leaks several years ago. Not wanting to go with a non-Toyota part in his truck, he did exactly what you described and removed his radiator and had a local shop fix it. He has not a problem with it since. I'm glad that you replied because the purpose of my Thread was to find out if any others had heard of what this guy had done and if it really worked. My only concern is that if over time the acidic nature of the coolant ate through the top of the radiator, what was it doing to the other parts and how long would they last after the top was repaired.
Again, thanks for the reply.
David
Old Oct 25, 2002 | 04:27 PM
Salue's Avatar
I had a slight leak when I got my '94, and it was tiny enough to just put some JB Weld on. It lasted for a few months, then it started to crack. I ended up buying one from Performance Radiator for ~$150.
Salue
Jun 1, 2021 01:51 PM
Road Bull
Oct 10, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
