2nd alternator
Old Aug 3, 2004 | 02:30 PM
2nd alternator
Hi all
I just put a new alternator in 200 miles ago. my charging light came on and i am only at 12-13 volts. I replaced the battery at the same time as the alt. I just bought the rig after it was sitting in a shop for a year. they replaced the opt. bat before they sold me the rig cuz its been sitting so long. hmmmm.
what would eat Alt. ? shorts in what? hmmmm
1985 4runner 22re
Fear
Old Aug 3, 2004 | 03:14 PM
Fahrenheit 451's Avatar
Where did you get the last alternator? Aftermarket alternators are notorious for being crap. I've had them last for only a couple thousand miles before and have even had them test them at the store before purchase only to discover they weren't any good right out of the box.
If it is someplace like Autozone or Checker that you got the last one, I'd say take it back for the warranty, stick in the replacement, but have them load test it on the bench before installing then afterwards also.
The last one I got from Autozone after having a short lived one, I got it back to the house to install it and noticed a sound coming from inside the alternator. When I checked I found an assembly screw floating around inside it. It was enough grief to go back to the store that I just pulled it apart and took the screw out. I believe it is the one I still have in my '85 4Runner. Something tells me it wouldn't have lasted as long with that screw floating around in it though
A bad battery can kill an alternator, but I doubt it could do it in only a couple hundred miles. Nevertheless, make sure and test it as well. Make sure all your contacts and battery cables are in good shape too. Lastly, any chance the bolts aren't tight enough and the alternator slipped? A loose belt could be a culprit.
Old Aug 4, 2004 | 04:43 PM
radrex's Avatar
I agree, most rebuilds are crap.. But you can get a good one if you keep trying - generally.
I buy mine at o'reilly's with a lifetime guarantee.. I make them replace it every time it craps out. Once so far. Heck of a deal for $98.00
Old Aug 4, 2004 | 06:23 PM
AKennedy87's Avatar
CHECK THE BELTS
Hah I ended up stripping the top mount that is the tensioner mount too so its been kiling the thing. But today my bro was driving my truck and It came real loose and the Alternator and water pump both stopped working thus no power and spray going everywhere,,,, So check your belts.
Old Aug 4, 2004 | 08:24 PM
amusement's Avatar
Suggest you check your charge fuse located off of the Yellow wire on the alternator.
The alternator will have a "L" stamped next to the yellow wire.
Old Aug 5, 2004 | 07:59 PM
took the alt back today and had it tested .....
FAIL!!!!!!!!
they replaced it ( ok handed me a new one )
installed
done !
o and i put new belts on cuz i was there.
Fear
Old Dec 22, 2004 | 05:53 PM
Albin's Avatar
Here's what I did to upgrade my alternator in my '85 4Runner:
http://www.rocketcityrockcrawlers.co...lt_Upgrade.htm
I hope this helps.
Al
Old Dec 22, 2004 | 08:02 PM
Bumpin' Yota's Avatar
www.hoalternators.com
I have a 190 amp unit and love it. 20k on it thus far...
Chicken12
Oct 14, 2015 03:54 PM
charlie_fong
Sep 27, 2015 10:06 PM
runnermedic
13
Sep 21, 2015 05:20 PM
SCZIG
Sep 20, 2015 09:00 AM
reallynotamechanic
Sep 11, 2015 11:52 AM
