22 to 302 Engine swap?
Old Aug 21, 2003 | 10:40 AM
nickormerod's Avatar
Question 22 to 302 Engine swap?
Hello out there,
I am looking for anybody that has performed a ford 302 engine swap into their Yota? I Picked up the truck from a friend a few months ago with a blown head gasket. Ended up putting a new head and aftermarket cam in it. Still no power though! I need more power to pull my Baja around on a flatbed trailer. Other than the lack of power the truck is awesome, even with 225k's on the ticker. Anybody aware of problems i might run into if i go with this swap. I plan on using all the NWOR parts that they make for this swap. I read that using the stock 5- speed tranny will work if not abused too hard? I have decided to go with the ford V-8 because i won't have to worry about power issues and because i want nothing to do with GM products; I.E. Buick V-6, Chevy V-6 or 350 V-8!!!!! I'd Rather keep my 22r than use a bowtie!! Any insights or help would be appreciated. Thanks
Old Aug 21, 2003 | 12:14 PM
wimpywade94's Avatar
i looked into it, it was gonna be so expensive that i would have been able to afford a old beater truck just to pull my other truck around with....youll find lots and lots of probelms when you do this swap.....ie your swapping in a ford not a chevy....
i now youll be
fixing
repairng
daily
later
wade
Old Aug 21, 2003 | 01:26 PM
slowyota's Avatar
Actually the 302 is pretty dependable engine. If you haven't already check out this web-site
Good luck. It'll provide you with a ton of power. And from what I've read pretty good gas mileage.
Old Aug 21, 2003 | 02:18 PM
Churnd's Avatar
That's a pretty cool site. I wish I knew that guy.
Old Feb 24, 2008 | 04:59 PM
broncota's Avatar
302 swap
im doing a 302 swap so for the motor trans transfercase is in just doing wiring the easy partEngine Swap Info
soon as i can i will have pics
Old Feb 24, 2008 | 05:01 PM
ozziesironmanoffroad's Avatar
ah, a ford man in our midst?
Old Feb 27, 2008 | 08:58 AM
hossmaster's Avatar
those 302 engines are durable! My old 86 with a 302 went 300k before I sold it and never had the engine worked on, hell I never had to change a gasket.
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
coryc85
Sep 9, 2015 06:24 AM
