2002 Rotor size
Old May 9, 2004 | 04:34 AM
raarco's Avatar
2002 Rotor size
I have a 2002 4Runner SR5 ( not the limited) , I have 16 in tires....I need to replace the rotors and when I go online and specify this Mod it recommends 15" rotor's.( I bought this used, did this vehicle come with 15" tires and the 16"s are optional ? ) , If I saw I am a 2002 limited owener it recommends 16" rotors. Please advise, what Rotor size should I order and any recommendation on after market rotors
Old May 9, 2004 | 03:28 PM
KZN185W's Avatar
For the Ltd, with 16" tires, the rotor outside diameter is 13".
You can check the rotor size by removing the tire then measure the circumference with a flexible measuring tape. Then use D = circumference/3.1416.
Another way is to get the radius and multiply it by two.
Still another way is check out the user's manual.
Re aftermarket rotors, go for DBA Slotted rotors. IMO, they're the best. check out http://www.dba.com.au
HTH.
Old Jun 2, 2004 | 05:05 PM
4Legz's Avatar
its just confusing info, the rotor itself is not 16in. You just need to specify what size WHEELS you have. In your case you would need the 16 incher.
justdifferentials
Just Differentials
Aug 30, 2015 08:42 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
anniesball
Jul 30, 2015 12:14 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
