2000 limited immobilizer key!
Old Mar 5, 2003 | 09:58 AM
knemo77's Avatar
hey guys i went to the dealership to get a new key for my truck because i only have one left. they told me 200 dollars for the key and if they have to reprogram the system if i loose all the keys its 1800 dollars....this sounds like a crock of Sh*$ abd i was wondering if you guys have done this cheaper than i am being told.thanks
Old Mar 5, 2003 | 10:14 AM
vtruong1's Avatar
I found this on ebay
Transponder Key
I wrote the guy and he said that all you have to do is go get it cut at someplace like walmart and he also give you instructions on how to reprogram. But I dunno....
Old Mar 5, 2003 | 07:43 PM
alanh's Avatar
I think the key cost is a bit high. I bought a new key for my 2000 and it was $41.50 a couple of years ago. I think they wanted 1/2 hour minimum labor charge to do the programming. The instructions for reprogramming are in the maintenance manual.
I don't think they're bs-ing you about about losing all the keys. You need at least one master key to be able to get the system to recognize a new one you want to add. I assume this is to make it harder for someone to steal the car, and just tell the system to recognize any old key. The owner's manual says the whole engine immobiliser system must be replaced if you lose all your master keys (the ones with black handles - not the grey one - if its like mine) and that is an expensive bit of electronics to replace.
Old Mar 6, 2003 | 07:04 AM
Outkast`'s Avatar
When I got my truck it came with only one key and for them to cut & program a new one the stealership wanted to charge me $75 outright...no labor. After 3 trips to the lot I ended up talking to a manager and he waived the fee. If you can find the thing on ebay or by other means, then by all means do it. But the sound of $200 for a key...Unless that bad boy comes coated in platinum, can talk, be used as a communication device, and a universal remote for a aftermarket cd deck, I'd have to flatulate in his area and then leave.
Good Luck,
Outkast`
Old Mar 6, 2003 | 08:56 AM
knemo77's Avatar
thanks for the advice guys i tell em to f off and find my ey elsewhere. im glad i checked before i bought one. :pat:
Bourbonblues
Dec 15, 2017 05:43 PM
indawire
Nov 29, 2015 05:05 AM
EDTECH79
Oct 1, 2015 09:41 AM
potatopants
Sep 15, 2015 06:26 AM
JHalcyonM
Sep 14, 2015 01:10 AM
