2000 4 run 3.4l , Fuel injectors not spraying
Old Sep 26, 2012 | 01:46 PM
bimmer325es's Avatar
I got a 2000 4 runner 3.4l not running, fuel is to the injectors does not start, plugs are dry. Has good spark, Noid light on injectors says power, they are not pulsating. Changed the ecu out, anyone got any ideas ?
Old Sep 26, 2012 | 04:56 PM
SacRunner's Avatar
This is a FSM (factory service manual) for a 2002 4Runner: http://www.ncttora.com/fsm/1996/SIL/fsm/repair.html
Check the fuel pump control: http://www.ncttora.com/fsm/1996/SIL/...e/fuelpump.pdf
Check the injectors: http://www.ncttora.com/fsm/1996/SIL/.../inje/insp.pdf
Check the ECU: http://www.ncttora.com/fsm/1996/SIL/...zfe/terecm.pdf
Your 2000 ECU will probably have a different pinnout than the 2002, Toyota liked to change things around from year to year for some reason.
Have you check for codes using an OBD-II reader? You could have codes without a warning light.
Old Sep 26, 2012 | 05:25 PM
have scanned with a code reader, no codes. Replaced coolant temp sensor, ignition thing, fuel is getting to the rails, and cleaned injectors.
Old Sep 26, 2012 | 06:18 PM
rworegon's Avatar
Is there some sort of a security system in there doing something with the injector circuit? Have you checked all the fuses i.e. EFI fuse, etc.? All ground wires under the hood in good condition and hooked up?
Charecter1
Nov 6, 2023 10:08 AM
steve miller
Oct 10, 2015 01:40 AM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
