2" sus. lift in the front...should i drop the diff?
Old Feb 25, 2004 | 08:48 AM
Mean04Tacoma's Avatar
well i want to do the manual hub conversion just because of all the bad things ive heard about the ADD's. so i may just do a 2'' coilover that i can adjust later and do a 2 and a half in AAL in the rear. and then when i get the conversion i will do the shackels in the rear and crank up the front to 3 inches.
Old Feb 25, 2004 | 08:49 AM
well the conversion i wanna do guys out the front diff and puts in all new, stronger, longer lasting components.
Old Feb 25, 2004 | 08:53 AM
http://www.offroadsolutions.com/imag...rsion_0332.jpg
Old Feb 27, 2004 | 07:29 AM
obxfishn's Avatar
I have a 2 1/2" spacer in the front and I have a diff drop kit installed. I now have a significant vibration in the front at around 25 mph and I can feel something similar at around 45 mph. It feels like the cv angle is off and feels like something is binding. I am wondering if I really needed the diff drop or can I take the drop kit off and do you think it would put too much angle on the cv's or do you think I would be alright. Can I do this w/o messing up the alignment.
Old Feb 27, 2004 | 06:18 PM
  #25
GRNTACO's Avatar
So you want to take the diff. drop out because of the vibration you feel? Taking the diff drop out won't mess up the alignment but may cause damage to your CV's. Did you lift the rear and if so how much??
Old Feb 27, 2004 | 06:52 PM
  #26
Tacoma Dude's Avatar
Did you have the alignent redone after the lift?
Old Feb 27, 2004 | 07:31 PM
  #27
obxfishn's Avatar
Yes I did, about 200 miles later
Old Feb 27, 2004 | 07:32 PM
  #28
obxfishn's Avatar
The back was lifted a total of 2"
Old Feb 27, 2004 | 08:49 PM
  #29
Birdman's Avatar
I do not believe the diff drop has any effect on the steering geometry. This only affects the angle of the half shafts and CV joints.
Old Feb 28, 2004 | 06:34 AM
  #30
RTdawgs's Avatar
the differential is supported by 3 mounts. the diff drop kits only lower the front 2, thus the tilted diff and apparently "there is a bearing in there that gets all screwed up"
Old Feb 28, 2004 | 07:29 PM
  #31
LarsDennert's Avatar
I guess we better stop driving around off road at 30 degree bank and tilt. The "bearing" could get REALLY screwed up. Funny but when I took my front diff apart, I didn't see the bearing that ORS could be refering to. Maybe mine doesn't have it.
Old Feb 28, 2004 | 09:45 PM
  #32
Mossback74's Avatar
So drive up ramps and change the diff fluid. Problem solved
Old Mar 1, 2004 | 01:24 AM
  #33
Birdman's Avatar
So is it possible to add a drop for the 3rd mount location? in al lhonesty, I haven;t looked at it....yet. I imagine doing this would change the driveline angle a bit but it doesn't seem like it would be enough to make much difference.
jaretstuff
Aug 4, 2015 02:08 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
coffey50
Jul 28, 2015 10:55 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
