1st Gen Supercharger Question
I have a 99 4Runner with a first gen. (Grey) supercharger, I removed the supercharger so it could be rebuilt. In the process I downloaded the instuction manual for the second gen. (Black) supercharger. I know it's different but I figured it would be handy for bolt locations, etc. In the second gen. instructions they talk about a one way valve that should be installed in the vacumn line at the bottom of the throttle body. My truck does not have this valve, and never has.
So, did the first gen superchargers ever have this valve installed? Was there ever a TSB issued for installing this valve later on?
Has anyone with a first gen supercharger installed one?
I bought the valve and have it here (it was cheap and I figured it was worth having it if I needed it). I just don't know if it should or should not be installed. Thanks for the help!
What valve did you purchase? If its the bypass valve it is located within a seperate housing attached to the 1st Gen case. On the 2nd gen it is NOT a seperate housing but all inclusive in the black housing case. That's one of the changes made when TRD produces the 2nd gens.
If thats not what you're describing, sorry! Pictures can help.
Regards.....8sm
Regards.....8sm
TRD Replacement Check Valve - One Way (3.4 V6 S/C) (PTR26-35042)
Check Valve One Way 3.4 V6 S/C supercharger check valve
So I did some searching and found the old directions for the 1st gen supercharger.
http://www.pballandmore.com/Download...tall_Guide.pdf
It looks like I have the super old version, I have the pre-cut TRD timing belt cover and the extra fuel pressure regulator.
In answer to your question about the valve, you want that in place, otherwise it will cause a boost leak.
Yeah, I decieded to install it. I think my supercharger was installed before that was part of the kit (I'm guessing when the 4Runner was new). I searched on TTORA and found a couple posts about people having issues when not using it.
http://ttora.com/forum/showthread.ph...er+check+valve
the1998sr5
15
Jul 14, 2020 08:35 PM
anniesball
Jul 29, 2015 11:46 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
