1st Gen Air Induction Service
Old Jun 10, 2005 | 06:28 AM
toyotablue's Avatar
I took the 1988 toyota 4-runner into the Dealership yesterday. It was idling at about 300 rpm, and I thought it was going to die at every stop light I came to.
Anyway, the problem was described as the "IDLE AIR BYPASS PASSAGE GUMMED UP WITH CARBON DEPOSITS". The fix: "REMOVED IDLE AIR BYPASS VALVE TO ACESS PORT FOR CLEANING". That being done seems to have fixed the problem.
However, the dealership always has something they recommend you do in addition to what they do to fix the job you request they fix. They recommended: "TECH RECOMMENDED AN AIR INDUCTION SERVICE TO CLEAR THE OTHER PORTS AND PASSAGES OF CARBON BUILD UP. EST $130
He described it as using some kind of fluid they run through the system. How can I do this on my own? What kind of fluid do you think they were talking and where do I pour it into my 1st Gen V6 engine? thanks,
Old Jun 10, 2005 | 07:37 AM
SupraSport's Avatar
UMMMMMMmmmmmm....... thats a pretty fancy name.
"AIR INDUCTION SERVICE" aka $130 BS
To help your idel:
Replace all you vacume lines (ONE AT A TIME PEOPLE!!!! LOL)
Fuel injector Cleaner in gas tank
Remove throtle body and clean inside with brake cleaner so that the flap seals nicely on the housing (be sure to re-install with a new gasket)
PCV replacement
Timing
Spark Plugs, Air Filter, Fuel Filter, Basic Tune Up ect.....
ENJOY
Aaron =)
Old Jun 11, 2005 | 07:08 AM
How about the famous "seafoam" through the PCV valve. that is prolly what $130 air induction service is.
Old Jun 11, 2005 | 07:45 AM
Beartracker's Avatar
Never got the hang of Sea Foam through the PCV valve hose. As soon as I pull the hose off me PCV valve the engine stalls.
Old Jun 11, 2005 | 01:01 PM
Adam F's Avatar
It shouldnt stall. it might stutter, but not stall. Try giving it some gas to keep it alive.
Eggslinger
Jun 8, 2019 03:32 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
noahstancik
Jul 17, 2015 05:38 PM
coryc85
Jul 6, 2015 04:07 AM
