1999 4Runner - What o2 Sensor Should I Get For My Situation?
Old Aug 14, 2010 | 08:55 PM
TheDurk's Avatar
Originally Posted by shaxs
So I got around to installing the o2 sensor today. It was simple. I drove around for 45 minutes to do errands and everything seemed fine. I then left the battery unhooked for 30 minutes to clear the CEL code. I started the car up and while in park and gave it some gas. The car now stutters for a second. I took it out for a short drive and from a full stop and giving it gas, the car stutters just a tad then goes and seems to be fine. Any clue what the heck I did?
When you use the battery method to clear a code, The ECU also 'forgets' all it knows about how to trim and time the engine. So it may just be re-learning your engine. This is normal. Give it some time and see if it improves.
Old Aug 15, 2010 | 04:38 PM
shaxs's Avatar
Thanks! My CEL came back on so I replaced the MAF. This time I went to Autozone and used their machine to delete my code. Hopefully this does the trick.
Old Nov 2, 2010 | 05:12 PM
rom164s's Avatar
Did deleting the code work? I've cleaned my MAF and then replaced front O2 sensor on my 99 4Runner, disconnecting the negative terminal after each, and the CEL came back both times.
Old Nov 12, 2010 | 02:07 PM
bradji's Avatar
I have a 98 3.4 Taco engine in a 95 4runner with 95 exhaust system (bought it this way). Any opinions if the front sensor is O2 or A/F?
Old Nov 14, 2010 | 06:13 PM
  #25
TheDurk's Avatar
You should have an O2. A/F's started in '99.
Old Jul 15, 2016 | 09:11 PM
  #26
Ron Helmuth's Avatar
Thanks The durk for all the excellent info
Longbed 90
Mar 11, 2019 12:38 PM
Keithstoyota
Sep 27, 2015 07:29 AM
zz_denis
Sep 6, 2015 03:43 PM
LJR
Sep 5, 2015 06:02 AM
