1998 to 1995 tacoma 3RZ-FE swap question
Old Aug 12, 2013 | 09:29 PM
fullwidthyotaon40s's Avatar
I just bought a 1995 Toyota Tacoma xtracab 4x4 with the 2.7L 3RZ-FE 5spd, motor in pieces in the bed. The only motor I have managed to find locally complete is a 1998 Tacoma xtracab 4x4 auto 10/98 mfg date 3rz with about 150k.
My question is can I swap this slightly newer motor into the '95 without major problems, i.e. sensors/manifolds/injectors/etc. If there are several things like sensors, afm, etc that is fine because I have the entire core motor in pieces.
Old Aug 12, 2013 | 11:30 PM
wyoming9's Avatar
Red face
The major problem might be swapping to the manual ECM either re pin the automatic harness to fit the manual ECM
It might be easier to just swap the engine harness from the manual ECM
You might get lucky and the plugs will be the same
In case you should have the EWD from both vehicles.
I guess it all comes down to your idea of major problems
Old Oct 2, 2013 | 10:09 AM
BigHoss_27's Avatar
you ever figure out if it would work
Did it work
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
Coreyr384
Jul 10, 2015 11:13 AM
Cplmike
Jul 8, 2015 08:47 PM
