1997 t100 engine into 1996 toyota tacoma
Old Dec 15, 2013 | 11:54 PM
Hachi808's Avatar
Hey guys. I need some help in determining if i will run in to any issues if I install a 3.4 from a 1997 toyota t100 AT into my 1996 toyota tacoma v6 AT? The 3.4 from the t100 has a lot less miles and I am wanting to install a supercharger. Please help. Thanks.
Old Dec 18, 2013 | 04:26 PM
mynameistommy510's Avatar
3.4 5vzfe onto an a340e or a340f transmission? The 3.4 from the t100 is the 5vzfe, correct? (unknown to me) shouldn't be a problem linking the two up. Going supercharger with an automatic will need valve body modifications to the transmission. Without the mods, transmission won't last long. Plus fuel mods are recommend. Sorry for assuming you haven't done the research.
Old Dec 18, 2013 | 04:34 PM
http://www.offroadsolutions.com/prod...engine-mounts/
Here's a website with some good info
Old Dec 18, 2013 | 07:13 PM
250000_yota's Avatar
Yes, it will work, but you'll need the engine wiring harness from the Tacoma and you'll need to swap the oil pan from the Tacoma engine. This means moving the dipstick location. Search 3.4 swap on here.
Old Dec 25, 2013 | 11:23 PM
DeathCougar's Avatar
Also need to modify the dipstick location, which means drilling a hole or changing the oil pump housing
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
PureTacoma_Tundra
PureTacoma_Tundra
Jun 29, 2015 09:45 AM
renorunnerguy
3.4 Swaps
Jun 28, 2015 09:18 AM
kctopher
Jun 16, 2002 04:07 PM
