1997 4Runner Tranmission Clunk
Old Mar 17, 2013 | 08:11 AM
chrisorbics's Avatar
1997 Toyota 4Runner Limited 4x4 automatic. I have been noticing for awhile that when I come to a stop and then let off the brake pedal and accelerate the transmission and the shifter jump. It feels like a loose mount. I looked at the bottom mount between the transfer case and the crossmember which looks ok.
Has anyone had a similar issue? Any thoughts on what and how I should check it?
Old Mar 17, 2013 | 09:23 AM
rworegon's Avatar
When is the last time the driveline was lubed? Loose motor mount?
Old Mar 17, 2013 | 10:45 AM
white_n_slow's Avatar
check your driveshaft u-joints. They usually clunk before going out all together.
Old Mar 17, 2013 | 11:16 AM
98SR54RUNNER's Avatar
Like others have said, most likely your u-joint. It needs a greasin'.
Old Mar 17, 2013 | 01:03 PM
tgmaul88's Avatar
change your trans fluid and filter id know the same clunk was on my 4runner untill i put new fluid and a trans filter in it and then no clunk
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 23, 2015 05:03 PM
