1996 Failed Smog - Advice needed # incl.
Old Feb 17, 2005 | 06:04 PM
rimpainter.com's Avatar
If it turns out to be the cat, just get a Carsound (Magnaflow) high-flow cat from ebay. I just got one for my project Celica (2.5") and it was $57 shipped. It was another $65 to have it installed at Midas.
Old Feb 17, 2005 | 06:05 PM
MTL_4runner's Avatar
Originally Posted by <96 Runner>
Well I totally believe Gadget; he would know. But I am just curious if it was only on some Taco's and not on all 4Runners...or what?
Doesn't really matter. It's mainly because I am curious.
I'd like to know myself.....just because I am curious too!
Anyone have a pic of the EGR on a 3.4L engine?
Old Feb 17, 2005 | 06:31 PM
nubreed's Avatar
Your right, I will check out the )2 sensor first. One of the posters above mentioned that the engine light should go on if the 02 sensor is bad. Is this always the case? Thanks for the advice guys, I appreciate it.
Old Feb 18, 2005 | 04:20 AM
No, this is not always the case.
The CEL will come on when if falls out of spec, but there is some variance in that which allows it to emit poorly until the ECU deems that the sensor is indeed bad and needs replacement. It seems like yours may be on the way (unless you just replaced it) and could allow emissions that are not passable while the sensor remains marginally in spec. The MAF sensor is another common reason why the engine can run lean so be sure to clean it will with some electrical contact cleaner as well.
Ichneumon
Sep 27, 2015 04:21 PM
BigArt70
Jun 30, 2015 09:51 PM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
HALMAN
Jun 14, 2002 09:02 PM
