15" rims on a 96 limited?
Old 01-21-2008, 05:29 PM
AK
AK's Avatar
I found a set of 15" 2nd gen 4runner wheels with bfg muds on them for a decent price locally. Will a 15" rim fit on a 3rd gen 4runner. if i remember correctly a 15" rim is to small due to the size of the brakes on the limiteds. Just wanting to get confirmation on this, thanks.
Old 01-21-2008, 05:30 PM
07sbock's Avatar
yea dude I tried doin that once and it didnt quite work out so well. if your 4runner came with 16s then thats the smallest rim you can go.
Old 01-21-2008, 05:34 PM
Dare44's Avatar
i had the same problem, i had bfg's with 15" rims and i cant fit them on my sr5, u can grind down the rotors, but i decided against it
Old 01-21-2008, 06:00 PM
ninjarunner's Avatar
Tried it too, does not work.. it kinda sucks, you could always swap the calipers for the tacoma ones........
Old 01-21-2008, 06:05 PM
AK
AK's Avatar
thanks for the replies. by the time i bought these tires/rims and then swapped calipers, it would probably be cheaper and easier to just buy muds for the rims i have now. thanks again
Old 01-22-2008, 03:35 AM
FullXTR's Avatar
FWIW I was going to do the same thing. I had a set of 15" wheels here that wouldn't fit, and I even had a set of Tacoma 15" calipers off a set of junked Taco rear ends I bought. The Taco brakes will bolt up fine, but they will require a different brake line -for some reason they have a different end where it goes into the caliper??
Anyways, I ended up not going thru with the mod because I didn't feel right going UP in tire size and DOWN in brake size.
primordialbeast117
12-19-2015 12:23 PM
Jdgarrison
10-01-2015 05:22 PM
Jdgarrison
10-01-2015 02:11 PM
Cycles
09-29-2015 06:37 AM
charlie_fong
09-27-2015 10:06 PM
Quick Reply: 15" rims on a 96 limited?
