04 Taco Engine Ping/Spark knock w/ only 79,000
Old Jul 30, 2015 | 10:26 AM
Tacoma1313's Avatar
2004 Tacoma 3.4 L 4x4 w/ 79,000 miles.
Truck pings/knocks under any load, through all gears intermittently. It will only do this when at operating temperature and is worse with the A/C on.
Higher octane gas helps a little bit, but not much.
List of things done to the truck recently:
New:
O2 sensors
MAF sensor
Air Filter
Plugs/Wires (plugs about 4-5K miles ago)
Coolant Change
Have run bottles of fuel injector cleaner every once and awhile.
Checked:
Codes/Freeze Frames w/ OBDII Inova Scanner. Nothing shown.
Gas mileage has been very steady, with a slight drop in city driving mileage.
No felt power loss.
Have not checked:
Vacuum lines for leaks
Extra air intake causing a lean condition
I am at a loss gentlemen and/or ladies. Short of taking it in to a mechanic to go through, I don't know what else to look for or check. I really don't think it should be pinging like this. My 94 22re doesn't ping like this unless I'm dropping the throttle in a high gear with the A/C on.
Any ideas would be appreciated.
Old Aug 7, 2015 | 02:23 AM
rworegon's Avatar
How did the vacuum hose investigation turn out?
Old Aug 17, 2015 | 05:44 PM
Tacoma1313's Avatar
No leaks detected. Really at a loss here. Seems like the pinging is random at times.
Its prob carbon buildup although seafoam and bg44k stuff hasnt worked.
polo451
13
Nov 20, 2016 07:49 PM
spruce
3.4 Swaps
21
Oct 23, 2012 01:59 PM
87toyy
Aug 16, 2009 04:08 PM
Matt16
7
Aug 14, 2009 08:37 AM
Paulsky
Dec 27, 2007 08:26 AM
