Yotasurf 1994 4Runner (Surf) Build-Up Thread
Old May 10, 2011 | 03:45 PM
yotasurf's Avatar
Here is my build up tread for my 1994 Toyota Surf. I have had it for about a year now and now its time to start with the mods to make it fit my needs. The truck is being changed from a daily driver to a work truck (majority steep logging roads)
Here is what I am starting with:
1994 Toyota Surf SSR
Front Shocks Bilstein Heavy Duty Series (B46-1468-H0)
Rear Shocks Rancho 9000
Steering Damper Old Man Emu (OMESD33)
Tires 35"x12.5"x15" Hercules Terra Trac
Rims Eagle Alloy 183 - 15"x10", 6bolt x 139mm
Body Lift 4"
Gear Ratio 4.10
Rear Diff Lockright 1620 locker
Front Diff Open diff
Front Hubs Asian manual hubs
Engine
1KZ-TE 2982cc
130 hp (97 kW) @ 3600 rpm
212 ft lb (287 N m)@ 2000 rpm
Old May 10, 2011 | 04:19 PM
yotasurf's Avatar
My bent spare tire holder
Work Box
4" body lift to be removed
Old May 10, 2011 | 04:21 PM
yotasurf's Avatar
Major to do list:
Body Lift Removal and new Tires and Rims
Remove existing 4" body lift and replace with new 1" body lift
Install 33"x10.5"x15" BFG AT mounted on 15"x8" rims
Suspension Lift
1.5" ball joint spacers
2" coil spacers
Diff drop
Panhard drop kit
OME Firm Suspension kit - from http://www.trdparts4u.com/scripts/pr...dproduct=-8463
1- OME 2901-Medium load rear coil springs
2- OME N72F- Nitro Charger Rear Shocks
2- OME N98 -Nitro Charger Front Shocks
1- OME 303003 Torsion Bar Set
Diff drop
Panhard drop kit
Fabricate and install front and rear bumpers
Build with both front and rear hidden hitch mounts forward plan for location of front mounted intercooler. Integrate both fog lights (hella) and blinkers into bumper
Install front mounted intercooler
and/or
Install water/alcohol injection system from devils own
Install 3" turbo dump pipe from toyotadiesel.com
Install Front Locker - Lock right 1611 front auto locker
Install hood louvers from http://www.man-a-fre.com/pa3/universalhoodlouvers.htm
There will also be lots of minor things that will be done to the truck.
If you guys have any recommendations let me know.
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Road Bull
Oct 10, 2015 04:55 PM
jon.r
Jul 11, 2015 03:34 PM
