xxxtreme22r's 1987 Pickup Build-Up Thread
Old Sep 6, 2012 | 01:48 PM
  #1541
RBX's Avatar
RBX
This reminds me, years ago my brother told me not to use the larger oil filter available for my then 87 xtra cab because it would lower the oil pressure and prematurely wear out the tensioner. I ran a larger oil filter because I thought more oil was better. Had one chain go up sooner then I thought it should, then he told me about the tensioner.
Old Sep 6, 2012 | 02:28 PM
  #1542
irab88's Avatar
that shouldn't matter; the filter is before the tensioner. if it was after, then it would matter. it goes: pan > pump > filter > tensioner > pan
Old Sep 6, 2012 | 02:44 PM
  #1543
RBX's Avatar
RBX
I'm just stating what i recall from the early 90's...before we had the interwebs.
Old Sep 6, 2012 | 07:59 PM
  #1544
snobdds's Avatar
If that really is a MLS (Cometic) head gasket, that is a heck of a price. Good find.
Old Sep 6, 2012 | 08:47 PM
  #1545
xxxtreme22r's Avatar
Doubt it's a true cometic gasket. I think the term MLS is used too much in the industry and leads to confusions on how to mill a block and head personally.
And as far as the oil filter deal, I only use the correct application PureOne Purolator filter.
Oil pressure per the guage was slightly low, just below the quarter mark at idle, but would jump to normal at regular rpms. So that oil leak between the block and tensioner wasn't affecting overall oil pressure like a missing galley plug would.
As far as the larger filter deal, the only drawback to that would be starting oil pressure if the filter didn't have an anti-drainback valve or that valve failed to keep the oil in the filter. It would mean it would take slightly longer to fill the oil filter when it was sitting long enough to empty the filter. Once filled it would not affect oil pressure, at least not near enough to matter.
Old Sep 7, 2012 | 02:37 AM
  #1546
RBX's Avatar
RBX
Brandon,
Your possible new rig is real nice, I hope it comes thru for you.
Old Sep 7, 2012 | 03:24 AM
  #1547
ChefYota4x4's Avatar
X2 on the 83! WOOT! Now I REALLY miss mine, haha... Wow, very little rust apparently? I loved having the longbed, personally. With a shell on it was quite the lil camping spot, plenty of legroom
Really hope this works out for ya, Brandon
Old Sep 7, 2012 | 03:48 AM
  #1548
92 TOY's Avatar
I still have the engine stand.
I also have a floor jack transmission cradle...still new in the box.
like the 83 also. needs to make up it's mind what color it wants to be though.
Old Sep 7, 2012 | 10:55 AM
  #1549
The 83 is gonna be quite a bit of work to get it running. It goes beyond just the engine trans and t-case. It needs a fuel tank, radiator, and the brakes looked at. Not sure about clutch lines. A SBC is sitting in it right now with an auto trans. I'm beginning to think it's not worth $500. And it's got a bearly passable set of 35's on it.
Old Sep 7, 2012 | 11:13 AM
  #1550
OH wow, that sux! Well..... you'll figure it out. Weigh it all out and then jump or back up, yeah?
Old Sep 7, 2012 | 11:36 AM
  #1551
Depends on how long I want to be without a truck and if the GF minds and if I have the area/means to have it down that long. The 83 after researching is a PITA to find a tank for. The guy has an 84 one, but it's different. Oh yeah and it's titled and vin'd as an 84 not an 83 for some stupid reason. And it might be an out of state title.
Old Sep 7, 2012 | 11:57 AM
  #1552
racerflea's Avatar
I say keep the sbc and tranny due to the fact you would need to get new motor and tranny mounts
Old Sep 7, 2012 | 12:15 PM
  #1553
racerflea's Avatar
also if u keep the sbc motor and tranny u could do a gauge swap like this
http://www.powerblocktv.com/player/s..._num=TK2012-03
im planning on doing this to mine and for the tank then u could get a s10 tank and make it fit... good luck!!!
Old Sep 7, 2012 | 01:38 PM
  #1554
the SBC that is in there uses the OEM 4cyl mounts using an adapter. The GM transmission is mated to the Toyota transfer case. The adapter will come with the truck. I'll sell that later. The cross member I was told is still in the same location. Mounts the same.
Old Sep 7, 2012 | 08:18 PM
  #1555
So you're yoinking the SBC fo sho? Going back to the 22ReeeeeeeeeeK? Interesting... I read what was in it and thought right off, "OH MY, he's gonna go MUD PSYCHO ON US NOW! " hehehehe.
Old Sep 8, 2012 | 01:46 AM
  #1556
racerflea's Avatar
Then that truck must have been a suto to start with i nelieve the standerd toy tranny is much shorter that a th350
Old Sep 8, 2012 | 07:36 AM
  #1557
racerflea it's a long bed. I may have to move the cross memeber which is easy, but the transfercase mount is the same. The mount on these unlike a Chevy is on the transfer not the trans. Unless I am brain farting.
And No Chef, the SBC was never a consideration. The guys selling the engine and trans from that truck separately. I don't get it for the $500. Besides I like the 4cyl mud bog classes around here.
I'll save a SBC swap for a 2wd 1st gen and make a street truck out of it.
Old Sep 8, 2012 | 07:46 AM
  #1558
mightymouse's Avatar
After making sure the frame is in good condition and it is worthy of building if you feel as though you have no other options on a gas tank pm me your year make and model with all other important information on the truck along with your shipping address and i will get you a quote. I'm not going to sugar cote it it will be pricey to purchase and ship but i should be able to get you one for your truck. Going from your ifs truck to solid axle and especially a 83 you will love it.
Old Sep 8, 2012 | 07:59 AM
  #1559
Right. It's an 83, I can't find an aftermarket tank for it at all and it seems the OEM tanks up to 82 and 84- are different then this 83. It's like a bastard child. But again, I haven't studied these gens all that much. I could be reading the applications wrong.
I'll keep you in mind. Thanks.
EDIT:
I think this is the right part number. As long as the long beds were the DLX and SR5's and not a base model.
77100-35191
Truck, Pickup 1981.11-1983.07 4cyl 2.2L MTM SR5
Truck, Pickup 1981.11-1983.07 4cyl 2.2L MTM DLX
You have the LN40 which is what this is for, then you have the RN3 and RN4's. I assume the RN's were the short beds unless the LN40's were the 2wd trucks. I don't know. Not much info on the frame codes out there.
EDIT #2 Scratch that: LN40 is the 2wd.
1979-1984 Toyota LN 40 2wd (Lifted NA Front, NA Rear) - Rancho RS9000XL Shock (Rear)
Old Sep 8, 2012 | 08:09 AM
  #1560
racerflea's Avatar
Ur truck might been made december 31st at 23:59 on a friday hahaha lol jk good luck in ur search
