WHAHAHAJR 1992 22RE 4x4 build or should I say rebuild
Old Dec 15, 2011 | 10:01 PM
  #41
RMP8080's Avatar
Originally Posted by WHAHAHAJR
I hate the egr system on our trucks
Can you do a EGR by-pass, I did one to my VW TDI
Old Dec 15, 2011 | 10:02 PM
  #42
RMP8080's Avatar
Had did the cam get damaged?
Old Dec 16, 2011 | 07:09 AM
  #43
WHAHAHAJR's Avatar
Thats the old cam. Not sure but it was definitely over torqued in the head. Having problems. A new valve guide broke.
Old Dec 16, 2011 | 03:00 PM
  #44
RMP8080's Avatar
oh man,that sucks
Old Dec 17, 2011 | 05:10 AM
  #45
WHAHAHAJR's Avatar
#4 valve on intake side is bent. Thinking it got hit in shipping or something. The top half of it is bent. It does not look like it got hit by a piston. The truck was never fired up. And same one with broken guide.
Old Dec 19, 2011 | 05:13 PM
  #46
WHAHAHAJR's Avatar
Got a new guide and valve installed at machine shop for $21.00 including parts. Head is back on and timed. Still need to adjust new rockers and put upper intake on.
Old Dec 19, 2011 | 05:16 PM
  #47
WHAHAHAJR's Avatar
Have to finish it up tomorrow. My week is all jacked up. I'm off Wednesday. (Got to take the wife out it's our anniversary.) Than back to work Thursday. Then got Fri Sat Sun off.
Old Dec 20, 2011 | 08:38 AM
  #48
WHAHAHAJR's Avatar
I was thinking about getting the block off kit from LCE but have not decided yet.
Old Dec 20, 2011 | 01:01 PM
  #49
RMP8080's Avatar
Only bad thing with a EGR by-pass is the computer, my vw its a diesel and it smokes a lot.
Old Dec 20, 2011 | 07:39 PM
  #50
WHAHAHAJR's Avatar
Smokes after the bypass kit?
Check out LCEngineering site. They have a kit and a simple fix if you get a check engine light. For your Toy.
"This EGR block plate kit contains all plates needed to eliminate the EGR systems on 22RE/RET fuel injected engines. This kit will include: the 3 bolt plate that bolts on the cylinder head behind the intake manifold and the 2 bolt plate that bolts to the intake manifold. Bolts and washers are also included in this kit. The cylinder head plate uses the intake manifold gasket and the intake plate gasket only comes in gasket kits. If you do not have these gaskets we recommend using a thin layer of Ultra Grey silicone sealant. If your vehicle is equipped with an EGR Temp Sensor then a 10K resistor can be used to keep the CEL Code from coming on."
Old Dec 20, 2011 | 07:40 PM
  #51
WHAHAHAJR's Avatar
Talking
She's alive!
Feels good to have her running.
And parked back in my drive way.
Old Dec 20, 2011 | 07:57 PM
  #52
WHAHAHAJR's Avatar
Thumbs up
Drove her home after work. You can feel more torque with the new cam.
They advertise it to "create a strong low-end torque curve while still providing good pulling power up to 5,000 RPM". But mainly feel the curve in the low end.
Trying to take it easy and let everything brake in. Sucks seems like its been raining off and on the last 3wks its been down. Can't wait to take her out to my buddies farm for some trails...
Old Dec 20, 2011 | 11:07 PM
  #53
john4wd's Avatar
Congrats bud, way to go!!!!
Old Dec 21, 2011 | 07:05 AM
  #54
WHAHAHAJR's Avatar
Thanks. It had a nice lope which I thought was from the cam. Turned out I left the EGR tube loose. Oops. Now it idles alot smoother.
Old Dec 21, 2011 | 09:40 AM
  #55
john4wd's Avatar
Smooth idle is awesome, the biggest pains could and most are easy fixes, just takes time to find then :}
Old Dec 21, 2011 | 11:49 AM
  #56
RMP8080's Avatar
Great on getting it working, it was ways feels good. keep upgrading......
Old Dec 22, 2011 | 06:14 AM
  #57
WHAHAHAJR's Avatar
Heater is not getting as hot as it use to. Either from the new thermostat or still got air in the system.
Old Dec 22, 2011 | 07:24 AM
  #58
WHAHAHAJR's Avatar
Love having my truck running again.
Old Dec 23, 2011 | 06:45 PM
  #59
WHAHAHAJR's Avatar
Let it run in my drive way which is at about 30 degree angle with radiator cap off. Think i finally got the air out of the system. Heater working good and no more high idle.
Only good thing about my drive way. I don't have to jack up my front end to get the air out of the coolant system. This is an old pic but this is how she looks right now. Lil muddy. Should go out to my buddy's farm tomorrow for some real mud...
Old Dec 23, 2011 | 09:21 PM
  #60
RMP8080's Avatar
Cool mud on the tires but the rums are clean nice................
