Roark's '89 pickup build
Old Mar 25, 2014 | 07:19 AM
Roark's Avatar
Then, to address the overheating issues cylinder 6 has on the V6, I invested in a set of headers. I got lucky finding a new "used" set of Downeys with all mounting hardware:
Mocked up real nice like:
Had to cut these guys off.. I wouldn't have done it if they had just given in to my wrench
Size:  190.6 KBName:  IMG_5018_zps73bae547.jpg
After some finagling (and help), I was able to mount them:
Size:  92.2 KBName:  IMG_5168_zps345c38ff.jpg
Had to relocate the gas lines to avoid the header's heat. (think 92 Toy's 4Runner)
I decided against mounting the EGR and PAIR reed valve. One, they took up unnecessary space. Two, they likely didn't work well in the 80's, let alone the 2010s. So, I cranked the bolts down with pennies for a temporary fix before I could come across a welder.
Hacked the exhaust(again, temporary), just to get the O2 sensor:
Cut up an EGR cut off plate:
Lastly, picked this up from Summit to wrap the headers at the most congested spots. I had an inch or so even in the tightest spots between headers and gas or break lines, but I figured the added $20 would be well worth the peace of mind.
Old Mar 25, 2014 | 09:16 AM
Gizler00's Avatar
Damn thats alot of work you got done!! Great score on the Headers. Those are going to bring the temps waaaay down back there behind the head. I bet you feel a big improvement in performance also.
Old Mar 25, 2014 | 09:30 AM
Roark's Avatar
Prior to these jobs, I hadn't ever done any mechanic work. One time, I watched my dad change the oil.. That's about it. LOTS of reading later, I tried this stuff myself. The headers cooled it down a little on the temp gauge, and I notice a little more top end, but not enough to warrant their purchase as a power modification. Peace of mind, though? All day.
Old Mar 25, 2014 | 10:38 AM
rattlewagon's Avatar
Nice job with the headers!
Old Mar 25, 2014 | 11:23 AM
  #25
Roark's Avatar
Thank you, sir! I definitely got lucky with those things..
Old Mar 25, 2014 | 11:34 AM
  #26
chukarhunt's Avatar
Glad to hear another report on the headers. I debated buying a set, but $600 just didn't seem worth the little gain. At least you got a deal.
Old Mar 26, 2014 | 06:08 AM
  #27
Roark's Avatar
I was very lucky, indeed.. Hopefully they will prove their worth by preserving my original head gasket!
Old Mar 26, 2014 | 06:11 AM
  #28
Roark's Avatar
Random shot with the smittybilt bumper:
Both "new" doors I bought from parts dealers looked like this:
So, they got the hillbilly treatment while waiting for a replacement:
Old Apr 10, 2014 | 07:23 PM
  #29
Roark's Avatar
Booty jank Alabama rusty exhaust:
Flat leaf springs:
PO's welding mess:
Old Apr 10, 2014 | 07:25 PM
  #30
Roark's Avatar
After my power steering pulley killed the battery and did this.. Name:  426FBD4E-ADDC-427F-B474-DADADDC0D1A7_zpsa5nilfe3.jpg
Size:  82.9 KB I put a little metal together for a battery box: Name:  1B3B13B9-147D-4F21-8483-33256B7BD9EF_zps8yj6vqrq.jpg
Size:  79.2 KB Found a factory center console: Name:  1AC180E0-9034-46BB-A4D3-B876A49B8577_zpsx5gqiq4q.jpg
Size:  147.3 KB Infinitely useful rubber mat: Name:  16818DAD-B3F3-4914-8EA0-3D36CD2F6CF8_zps6phjaa9o.jpg
Old Apr 10, 2014 | 07:32 PM
  #31
Roark's Avatar
Like all 3vze owners, I did an ISR:
Mandrel bent solutions pipe/silicon, plus a custom job rerouting the stock vacuum hoses.
When I installed my headers, I removed the emissions equipment and just plugged the holes with pennies. At some point, I welded some steel bar to the caps and torqued them down!
Which included removal of all the excess vacuum hoses! Much cleaner engine bay! Simpler, more room to work, and overall sharper!
Old Apr 14, 2014 | 05:04 AM
  #32
83Toyota88's Avatar
Good score on the headers.
Old Apr 14, 2014 | 07:39 AM
  #33
WVYOTABOY29's Avatar
How did you do the egr removal? I have a 3vze and I'm planning on doing the same.
Old Apr 14, 2014 | 08:01 AM
  #34
Roark's Avatar
https://www.yotatech.com/forums/show...923&styleid=51
https://www.yotatech.com/forums/f116/egr-removal-106914/
I used those two threads for reference.
Essentially, you remove the EGR/PAIR that are both on the passenger side of the engine, plus the EGR vacuum regulator that is on the far left of the fuel rail that runs across the top of the engine closest to the radiator. After that, remove all hoses that are to or from those 3 things. There's a few smaller ones, a few bigger ones, and one huge one that comes from the PAIR that wraps around the back of the engine near the PCV valve. After that, you've got to fab up a plate to cover the hole left from removing the EGR. A little aluminum or steel or even coke cans will work. Just cover it up, and you're good to go!
Old Apr 16, 2014 | 06:13 AM
  #35
Roark's Avatar
When she was young and spry:
Found this at walmart (last one!) for 95¢:
Old Apr 30, 2014 | 01:13 PM
  #36
Tabasco Kid's Avatar
It is nice to see another YoTa owner that takes care of their toys. Anyways, all u need to do now is to mount your MB 4Runner to a "gyro" so that it will always ride level & true no matter how twisted up you may be in the woods.. hehehe.
Old Apr 30, 2014 | 01:26 PM
  #37
Terrys87's Avatar
You are doing a great job and being this is the first truck you have been working on have been doing extremely well. Great job!!!
Old Oct 18, 2014 | 10:22 AM
  #38
CamTom12's Avatar
Great build!
Old Oct 18, 2014 | 10:35 AM
  #39
Lets get a sound clip with the headers!!
Nice work with the EGR/Pair. Really cleans up the engine.
Old Oct 19, 2014 | 03:17 PM
  #40
Roark's Avatar
Hey man, I take care of my truck. It's just the deer and the icey highway that didn't..
