Reverse Lights
Old Dec 1, 2023 | 06:06 AM
Studs's Avatar
Reverse Lights
Hello,
Looking for advice. 1989 Toyota 4WD manual transmission pick-up truck. Reverse lights not working. Fuse, switch, wiring, bulbs all check out. Apparently, whatever pushes on the switch inside the transmission is not doing it's job or needs adjustment.
Any help or advice would be appreciated. Thanks in advance.
Old Dec 12, 2023 | 06:35 AM
rattlewagon's Avatar
There is a sensor on the side of the trans that triggers the lights to come on. You got a v6 or a 4cyl?
Try this thread: https://www.yotatech.com/forums/f160.../#post51488087
Kolton5543
Nov 1, 2017 06:25 AM
Yotadawgjr
15
May 11, 2012 11:52 AM
juniorg26
Dec 28, 2009 12:19 PM
eyeseeyou
May 4, 2009 09:53 PM
mokai
Sep 23, 2007 03:45 PM
