Idiot moment 3VZE
Old Jul 1, 2017 | 05:43 PM
Old Yota Racer's Avatar
Idiot moment 3VZE
Replacing my timing belt on the "love child" and the timing belt I bought does not have the timing marks on it. How will I know if everything is right when I put the new belt on?
Old Jul 1, 2017 | 05:55 PM
akwheeler's Avatar
line up the timing marks on the crank and cam pulleys. if you line them up before you remove the old belt you are better off,
Old Jul 1, 2017 | 06:44 PM
Did line them up with the old belt on, so if I ,make sure everything is tight around to the tensioner pulley Ill Be OK?
Old Jul 1, 2017 | 07:39 PM
hidesert's Avatar
You should be. Rotate the crank two complete revolutions. If the marks still line up, you're good.
