Highlux's 1988 4Runner Build-Up Thread
Old Oct 5, 2010 | 05:19 PM
HighLux's Avatar
I should be fine...I switched the WHOLE rocker assembly and cam. Both came from same motor...so they are broke in together.
Old Oct 5, 2010 | 05:30 PM
xxxtreme22r's Avatar
ah good deal, two of those rockers looked kinda like they were over heated, but maybe that's just some carbon build up from old oil.
BTW, it looks like you got something on your camera lens. Better go clean it off. hahaha
Old Oct 5, 2010 | 06:29 PM
HighLux's Avatar
Ahhh..good eye my friend...good eye...I will clean the lens right away.
Old Oct 5, 2010 | 06:37 PM
mightymouse's Avatar
hey did the pats from egnbldr come in today? I got my brake line issue figured out. What a pain in the butt. (Re read the post so yeah they came and it looks as though you're good to go) You made short work of the swap up top nice, hope it holds.
  #25
toyospearo's Avatar
nice work!
Old Oct 5, 2010 | 06:44 PM
  #26
HighLux's Avatar
Read a few posts up silly......sorry I couldn't find my flare tools. I looked everywhere. I hate not being able to find a tool. I generally know where every single one is.
Thanks toyospearo.
I cant wait to tear into it tomorrow and get her running.
Old Oct 5, 2010 | 06:46 PM
  #27
edited for my slow to read butt, sorry long day.
Old Oct 5, 2010 | 07:04 PM
  #28
HighLux's Avatar
Oh....the second headbolt back on the drivers side scared me....just about broke a 1/2 drive breaker bar on it...was tight...every 1/2 turn I was talking to it....please dont break off in the head...please dont break off in the head.
Goodie pictures....
Water pump
Timing set
Oil pump
Timing cover
Old Oct 5, 2010 | 07:09 PM
  #29
HighLux's Avatar
oh....cleaned the wheels up...prepped em and painted em. Did this over last weekend.
Old Oct 6, 2010 | 10:13 AM
  #30
HighLux's Avatar
OK....all tore down and ready to go back together.
Scraping the timing cover gaskets kinda sucked.
Hardest part so far...lol
That timing cover was a little more wore than I thought....I bet it was pretty close to wearing through to the coolant passage.
I am FILTHY. Thats one dirty little engine.
Taking a break...Ill snap a few pics before I go back at it....I wanted to take more pictures....but the drive to get it done is kinda exceeding that desire.
Did I mention I am FILTHY.
I miss modding brand new cars....lol
No real suprises though.
Filthy...one more time.
Old Oct 6, 2010 | 12:16 PM
  #31
HighLux's Avatar
ok taking another break and chugging a rockstar.
Timing set up installed.
Waterpump installed ( engnbldr waterpump studs are a little too short. barley worked.)
Oil pump installed.
timing cover on
Working on a/c and the rest of the accessories, etc.
Yes..still filthy. Oh...and amongst the fury of activity....found my flare tools....sorry mighty mouse...day late and a dollar short.
Ill load the pics up when Im done or I quit for the evening.
Old Oct 6, 2010 | 12:21 PM
  #32
yotarob2005's Avatar
If you would quit taking so many breaks you would be done already.
BTW, I think I read on somebody elses thread they had the same problem with the water pump studs being short for the timing cover...... IIRC you reuse your old ones to the t-cover & the new ones are for the water pump to fan. I could be wrong.
Old Oct 6, 2010 | 12:25 PM
  #33
HighLux's Avatar
I will investigate.
This is my second break since like 9 something...and that includes cigs.
Old Oct 6, 2010 | 02:59 PM
  #34
HighLux's Avatar
Ok, last break. I have to adjust valves....put in some water...and some oil. Then fire her up and check the timing.
Old Oct 6, 2010 | 03:17 PM
  #35
once you start it just be prepared for it to run a little wired and hiccup a little, all it is is the coolant bubble freaking out the coolant temp sensor. Make sure you start it without the rad cap on, it may or may not spit some out at you though.
Old Oct 6, 2010 | 03:21 PM
  #36
92 TOY's Avatar
no...you are right Rob...had to re-use mine and use the studs for the fan.
holy cow man....i'm excited for ya.
yes...get ready for it to lope a bit while the bubbles work through the cooling system
Old Oct 6, 2010 | 03:36 PM
  #37
HighLux's Avatar
Well...after I sat down....I realized Im exhausted.
Shouldn't of stopped. I'll wrap it up in the morning.
I'll make sure to burp her. I know a trick for that.
I'll be happy when it doesnt sound like a machine gun from those rockers beating the cam to death.
Im covered with wounds, and tired as hell.
Ill go get some oil,filter, and some coolant in the morning.
Good news is....I matched up the piece of drivers side guide I fished out a couple weeks ago with what was left bolted and there should be little to nothing in the pan.
Old Oct 6, 2010 | 03:37 PM
  #38
92 TOY's Avatar
good plan.
Old Oct 6, 2010 | 03:40 PM
  #39
I was pretty sure, searched your thread for a few minutes and didn't stumble on it.
Old Oct 6, 2010 | 03:41 PM
  #40
92 TOY's Avatar
hehehehe....depends which thread.....the 1st one can take a few days to read.
