HARRENSTEIN's 93 4runner Build-Up Thread
Old Jun 7, 2010 | 08:35 PM
HARRENSTEIN's Avatar
I am finally the owner of a toy! I was looking for a Tacoma for a while but found a good deal on this 4runner and I really needed something to haul my dirt bike. I picked this gem up for $460. It had a 3.0 and the owner said it had a bent rod but after tearing it down I found it was actually a bad connecting rod bearing. Not wanting to machine the crank and rebuild the 3.0 after everything I have read about them I decided to start looking for a 3.4.
Shortly after looking I found a engine trans and t-case for sale on this forum for $1200. (which if anyone needs an auto trans or t-case for a 2001 tacoma they are for sale - I am in southern Minnesota). So now I have got the 3.slow out and have started preparing the 3.4 to go in. I ordered a clutch kit and timing belt to get me started.
Now for my biggest challenge... My truck is a manual and the 3.4 came from a manual. I am going to try and make this ecu work. So if anyone has any advice on this post away.
Other then the motor the truck is in pretty good shape for a minnesota toyota. I ditched the running boards and gained some nice clearance. It has some 285/75-16 tires on it but they are about gone and the rims just look horrible so I am getting some 15x8 steelies and either 31 or 33 x 10.5" tires. Not sure what yet.. maybe bfg all terrains or something similar. Any suggestions here would be great. Sometime in the future I might add some ball joint spacers and lift springs.
Also, I will be building my own bumpers front and rear. I will post some pictures when I get some designs started.
The day after I picked her up.
More Ground Clearance
Room for the new bumper.
Old 3.slow
Dirty Rusty Engine!!
Deffinately need a new timing belt.
Started painting the 3.4... its not perfect but much better then the before.
Old Jun 21, 2010 | 08:29 PM
Well I figured I would finally update this thread after getting some work done. Mostly been cleaning and painting this dirty engine. It looks a lot better now, I think anyways.
I got the 3.0 oil pickup, baffle and oil pan on now. As well as the 3.0 oil sender.
I have to stock crossover bolted on to see how much it would take to make it work. I think I could move the flange a bit and make it fit by the clutch solenoid. However, I would have problems by the time I got back to the transfer case. So... I am trying to find a ORS crossover for a reasonable price or might just buy an exhaust kit and make my own.
I have the 3.0 engine harness out of the truck and got the engine bay cleaned up. I am going to be making the battery tray here soon as well as a custom front bumper. Hopefully I can get the motor in soon and start tackling the wiring. I've been tempted to just buy a manual trans ECU but I think I'll just try the auto for now until i get the motor running. Then I figure its just plugging in a different ECU and probably changing a few wires around.
Old Jun 22, 2010 | 07:37 PM
RobD's Avatar
Perhaps it's just me, but none of your photos are showing up.
Never mind...just impatience on my part...continue with your regularily scheduled programming.
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
jon.r
Jul 11, 2015 03:34 PM
crashburnoveride
Jul 10, 2015 06:39 AM
