Green Bast 4Runner 7MG-TE SAS build
Old 04-19-2014, 06:49 AM
Fossilized
Staff
dropzone's Avatar
81-83 front axle
make sure you truss it and add the knuckle ball gussets while you have the chance.
gonna be awesome when you are dine
Old 04-19-2014, 07:32 PM
saskyrunner88's Avatar
Trusty Toyota Welding unit
Old 04-19-2014, 08:46 PM
chukarhunt's Avatar
^^^^ I don't care who you are, that there's funny!
Old 04-22-2014, 07:39 PM
Parts have come in. No excuses now, time to get it done!
Old 05-03-2014, 11:39 AM
  #25
First time she has seen daylight since before winter!
steering box relocation (I know the angle looks bad on the shaft but it turns smooth)
Chevy 63's with double shackle setup
Old 05-03-2014, 08:25 PM
  #26
BigBluePile's Avatar
Those shackles look......interesting.
Old 05-05-2014, 11:20 AM
  #27
and what would you mean by that?
Old 05-05-2014, 06:28 PM
  #28
Are those shackles braced? Bracketed to prevent them from swinging the other way?
Old 05-19-2014, 09:55 PM
  #29
no they sure aren't bracketed in that picture haha I was just excited to get the axles underneath and took some pics. I added bump stops for the top shackle and will be doing a brace to stop them from becoming a double jointed death trap shortly.
Old 05-19-2014, 10:02 PM
  #30
waiting on some parts so i figured what better time then now for some half doors. As you can imagine not much room for AC with this swap, so the next best thing!
Pick up some sheet metal tomorrow to finish them up
Old 05-20-2014, 06:25 AM
  #31
bump530's Avatar
Have you flexed your front suspension yet? It seems that the springs would hit the drag link under compression on the driver side with the steering box mounted like that.
Old 06-17-2014, 10:50 PM
  #32
yes it hits, haha when i ordered the steering components i really didnt know how everything would line up and made the mistake of going with the drop pitman arm. Flat one is on order and should be well out of the way
Old 06-17-2014, 11:08 PM
  #33
Had no luck tracking down the 5m mounts so shortened the 7mgte engine mounts and some steel to attach to the old 22re mounts. Dont have to relocate the dipstick which is a bonus? haha
Half doors done
velcro window
Engine and tranny in
Old 06-18-2014, 09:17 AM
  #34
rattlewagon's Avatar
Are they the sky shackle? They have a little tab on them to stop them from going the wrong way...
But its still a double shackle... Ugh.
I second the axle needing gussets! Dont put all that work into it just to have it bend.
If you rotate the steering box back the other way, youll fix that rag joint angle and still be able to use your drop arm.
Nice work on the 1/2 doors!
Old 06-18-2014, 09:36 AM
  #35
rustED's Avatar
^^^I was going to suggest the same thing on the steering box, if you took the top 2 bolts out and pivot the steering box the other way (counter clockwise) it would fix the rag joint, you'd have to relocate your top mounting holes tho, (might think about plating/reinforcing the frame at the steering box also as it will be a high stress area once your running bigger tires, you can make your own or buy TG or others for around $50. Nice work on the half doors, cool build so far, look forward to seeing some more!!!
Old 06-18-2014, 10:54 AM
  #36
ya Im having second thoughts about the double shackle setup, I dont like the idea of them unloading when you are in a precarious position. they seemed like a good idea when i read about them originally but they might get scrapped.
I will rotate the steering box and see if i can get a better angle and burn some gussets on today!
Old 06-18-2014, 10:59 AM
  #37
Thanks guys! Im pretty happy with the way the doors turned out.
Old 06-20-2014, 10:51 PM
  #38
Bracket
some light trimming....
New angle
Old 06-21-2014, 09:54 AM
  #39
nothingbetter's Avatar
I was thinking about doing that with my steering box too. but I'm might just go with a flat arm instead of the drop arm. Sounds like you ordered the flat arm but ended up rotating the box instead, want to sell the flat arm?
How much room do you have in between your rad/fan and the balancer on the crank?
With my front mount intercooler, rad and electric pull fan I have 1/2" of room from the fan to balancer...and your intercooler is much farther back than mine is.
Old 06-25-2014, 11:14 PM
  #40
Sorry dont have the flat arm
I probably have 1"maybe a bit more I will measure tomorrow. did you use the original transmission mounts or did you move everything back when you did your swap?
that pic with the intercooler was before i had the engine in and realized just how little room i was dealing with, no way it would fit like that. as of right now its looking like i will go with a top mount intercooler. I hear of some guys running straight off the turbo but i cant see that heat helping the longevity of your engine.
Quick Reply: Green Bast 4Runner 7MG-TE SAS build
