Dub Tek's 1991 Regular Cab > Build Thread
Old Oct 9, 2011 | 04:36 PM
dub tek's Avatar
Im Back AGAIN
1991 Regular Cab
22Re 5Spd
Picked it up with 167K
This will be my "INFO DUMP" for the truck and what I do to it
Vin
Frame Tag
The Day I brought her home
Load Testing It
MUCH MORE TO COME
Old Oct 26, 2011 | 04:39 PM
dub tek's Avatar
10-18
Replaced front shocks with procomp 1000+9000 in the rear
From summit racing (there 15min up the road)
Replaced the sway bar end links with some poly versions from summit
10-25
Replaced Upper + Lower Ball joints
OEM from the Dealer here in Akron
Also setup a vendor account with them so the OE is at a discount
($51 each + some hardware )
Replaced aftermarket Thermostat with a Genuine+Coolant swap
Couple of vacuum lines got swapped just cause
MORE TO FOLLOW
Old Oct 26, 2011 | 05:23 PM
westjohns yota's Avatar
this should be good......
Old Nov 24, 2011 | 04:14 AM
dub tek's Avatar
10-24-11 <Turkey Day!!
Preformed Valve adjustment @ OE specs.......
.008 int
.012 ext
Found Cyl's 1-2+4 intake valves WAY loose
Found Cyl 4 exhaust valve @ .004 <Tight!!!
Ill give it 2 weeks of driving and check again
I may set them a bit tighter then suggested
I have read some .006 + .010 on higher mile engines
As the wear pattern is established
Old Nov 24, 2011 | 04:15 AM
dub tek's Avatar
11-24
During valve adjustment for "loud valve train"
I checked the timing chain
I do NOT have the notorious "Drivers side guide" broken
The Chain is WAY loose so this is next
Old Nov 24, 2011 | 06:04 AM
Moonfish's Avatar
That chain is less fun. But more fun than pulling the tranny out. Keep an eye on the gear oil level in there. That is a super clean truck and I love those rims.
Old Nov 24, 2011 | 04:46 PM
dub tek's Avatar
Gear Oil Level?
You talking about a engine oil level
Old Nov 24, 2011 | 04:55 PM
dub tek's Avatar
Just ordered THIS CHAIN KIT FROM LCE Performance.com
Also ordered a water pump gasket
An oil filter and valve cover gasket kit with new grommets
Old Nov 25, 2011 | 03:31 AM
dub tek's Avatar
Todays Plan
11-25
Swap door contact switches for center light
Pass side is working A+
Drivers side has yet to kick the light
So a quick swap of the switch will verify the system parts as OK or NOT
Along with the same for the switches
While Im on the interior bits
Im going to pull the heater control face
The bulb inside is blown out (I hope this is the case)
And its getting annoying to NOT b able to see the controls when its dark
Old Nov 25, 2011 | 12:35 PM
dub tek's Avatar
OK
Short work of the 2 issues posted above
Found single wire connector for the switch behind drivers lower kick panel
Was UNPLUGGED... <Reconnected and wallalla
Light in dash for HVAC control was also blown
Replaced bulb and its all good
Found some nice wiring in there for the DIGI clock connector
So Ill be sourcing this at some point
AND I measured the center cubby and my CB will fit right in there nicely
Old Nov 27, 2011 | 07:27 AM
dub tek's Avatar
11-27-11
Stopped at pull a part
Snatched a NICE front and center/rear view mirror assembly from a 4runner
Has dual lights
Independently switchable
With door function (Now that I have both door switches working.. Its nice!!)
Grabbed a Digital clock as my Base model truck had a block off plate
Plugged it in and got NOTHING.....
So Ill need to test the wiring for constant B+ as well as the dimmer circuit
Ill also b adding power and Gnd to the digi light to test it
Old Nov 27, 2011 | 08:23 AM
dub tek's Avatar
Thinking about adding some sort of spare tire carrier to the bed side/tailgate
My under bed spare mechanism is... well..... rotted
So I need to do something!!!
Old Nov 30, 2011 | 09:14 PM
john4wd's Avatar
Your spare tire assembly has rust holes or just rusted solid? My old 84 spare tire crank down assembly in 2006 was rusted solid and would not move so I bought some Evapo Rust at Rural King or can be had at Auto Zone, I got a container with a lid and let is soak it for a while I don't remember how long, just read the directions and I let it soaked and it ate the rust and then it functioned like new and remounted.
On my 87 in mid 90's I couldn't find a non rusted up chain one and found a 2WD cable one that was perfect, it uses 3 bolts to attach to cross member and had to drill another hole in another location and the chain one uses 4 bolts. It probably was designedonly for the 14 inch rims and small tires there for using a cable not a chain and it held up great with a 15 inch rim and 30x9.50 tire mounted using it till I sold the truck in 2000...
Old Dec 1, 2011 | 05:41 PM
dub tek's Avatar
Its rusted to the point its flaking off
The stamped exterior "frame" of the height adjuster is trashed
X2 bolts are broken off in there locations
Im just going to scrap the entire idea of under bed spare tire
Old Dec 3, 2011 | 12:35 PM
dub tek's Avatar
Stopped by Pull A Part again today
there web site stated a new toyota just in.
VERY worked 4x4
had plow bracket on front end <LOL
scored an HD hook for the front frame rail
Got home removed the eyelet from the drivers side
Replaced with the new hook/eye combo
Also managed an "O ˟˟˟˟˟" handle from the pass side
I plan to install it on my drivers side at the 12 position
Old Dec 3, 2011 | 12:37 PM
dub tek's Avatar
NEED to know if I can use the "A Pillar Trim" from an extra cab
in my regular cab as direct fit?
Id like to add the "O˟˟˟˟˟" for both sides in my rig
Old Dec 4, 2011 | 08:16 AM
dub tek's Avatar
Scored @ pull a part AGAIN!!!!
SR5 stuff: Cluster w/tacho coolant temp. Oil Temp. Volt Fuel
Driver Arm Rest W/pocket
Turn Stalk With INT wiper
Center Console
Rear Window Lock/Latch
WeatherTech Fitted floor mats
AND a second digi clock
Along with about 50 interior screws
-There is also a SET of matching pepper pots like whats on my truck above
$60 on 4 of em`<Im debating a summer/winter set with summer/winter tires
Old Dec 4, 2011 | 05:12 PM
RMP8080's Avatar
Pictures please.............reads good...............
Old Dec 4, 2011 | 06:23 PM
john4wd's Avatar
Awesome sore on parts!!!!
Your toy is a 1990, did you get a full gauge cluster with speedo cable output for a cable speedo?
I leave the salvage yard with my pockets full of fasteners af what ever is lying on the ground or left in vehicles after some people remove parts, saves on having to go to ACE and pay money for common fasteners that are just lying around :}
Old Dec 6, 2011 | 04:44 PM
dub tek's Avatar
Your toy is a 1990,
The Build date is 11/1990
The VIN# + Title + Insurance state 1991
WIKI VIN DESCRIPTIONS < For support
