Drmix's 93 Extended Cab Pickup Build Thread
Old Apr 24, 2011 | 07:03 PM
drmix's Avatar
Thanks! I really need to post some newer pics
Old May 3, 2011 | 08:31 PM
drmix's Avatar
Just downloaded a photobucket app on my phone so I am able to upload pics pretty quick and easy.
Heres some pics of when I was doing my manual hub swap
My MT-90 that I bought for my tranny. Shifts smooth as butter now
A pic I took at the store a couple days after a wash
Decided to paint my chrome wheel trim pieces black. They turned out pretty well and look WAY better than before. I plan on slowly painting over the chrome since it doesnt look to well.
Old Jun 5, 2011 | 06:48 PM
drmix's Avatar
So last week I installed my Cobra 19 DX IV CB and 4ft firestik. I mounted the CB where the ash tray use to be and fits perfectly. I havent taken any pics of the yet but ill probably post some up after a while.
A couple weeks ago I also picked up a set of 15X8 rims that are in pretty good condition just need some new paint. Figured a couple hours of work and theyll be as good as new. Definitely worth the $30 I paid for them.
Then yesterday while I was at the wrecking yard picking up a couple random parts I spotted some almost new 33x12.50x15 BFG mud terrains. There was only 2 but I ended up getting both of them for $170. They got probably 90%-95% tread left. I always see people selling there brand new spare tires on Craigslist. I figured if I could find another 2 tires ill have a set of almost new tires for around $400.
Im probably gonna be painting my rims this week then hopefully find another 2 tires within few weeks so I can get them mounted.
Old Jun 6, 2011 | 03:45 PM
drmix's Avatar
Just some pics I quickly took today. I just washed and waxed her yesterday after a couple weekends of wheelin without washing
Old Jun 25, 2011 | 11:04 AM
  #25
mrl0690's Avatar
Nice cb soo jealous
  #26
mrl0690's Avatar
lets go wheelin
Old Jul 22, 2011 | 11:00 AM
  #27
ColbyP's Avatar
Nice lookin truck man
Old Jul 22, 2011 | 11:16 AM
  #28
Ty's Avatar
Ty
Nice truck!
I like the Cobra CB. I might be picking one of these up from a friend.
Old Jul 24, 2011 | 02:19 PM
  #29
drmix's Avatar
Originally Posted by Ty
Nice truck!
Yeah there pretty good little CB's and they fit perfectly where the ash tray use to be
Old Jul 25, 2011 | 08:28 PM
  #30
Teuf's Avatar
Drmix, did you tune the antenna via an SWR meter. I have that cb and a 6 foot firestick and i understand if you do not tune the antenna you could damage the cb?
Thanks.
Old Jul 25, 2011 | 09:18 PM
  #31
drmix's Avatar
Yeah I tuned it. I got it tuned to about 1.3 across all channels
Old Oct 5, 2011 | 08:14 AM
  #32
drmix's Avatar
Havent done much to my truck for a while just routine maintenance.
I did get my windows tinted a few weeks ago and it looks alot better. I got 20% all around with 5% on the moonroof which is about perfect for me. The back windows are super dark since they already had the factory tint in the glass. Ill have to post pics a little later.
Once I move and get a house expect more updates. There is no room for major projects when you live in a apartment with no garage. If everything goes good we should be in a house by the first part of next year.
Old Jan 8, 2012 | 09:17 PM
  #33
drmix's Avatar
Updated my info on the first post.
This weekend I built a new wiring harness using 12 gauge wire to prepare for my H4 conversion. I installed my harness this morning and noticed the headlights were only slightly brighter. I was hoping for better results but I dont think my wiring was too bad to begin with. Oh well the main reason I did it was to prepare for the H4s.
The H4 conversion should be coming in within the next couple of days so I expect to get much better results with those. For now I am going to be running the bulbs that are included with the housing until I figure out exactly which bulbs I want to run.
Old Mar 24, 2012 | 09:37 PM
  #34
drmix's Avatar
So I decided to go with the Hella 100/80W H4 bulbs. Ive been running them for a couple months now and they are amazing! They produce a nice white light and are bright enough to meet my needs yet not so bright that I am blinding people. If you are trying to decide on a good H4 bulb to go with I definitely recommend the Hella 100/80W!
This week I have been having issues with my truck. Last week one of my Ujoints started to go out. I had really bad vibrations when driving over 35 mph which was definitely a problem.
Fixed that issue, then yesterday it was a nice day outside so I decided that I would finally change the oil in her. Got ready to go pick up some supplies, started her up then went to check the coolant and a couple other things when all of a sudden it just died. Figured that was weird so I went to start it back up and it wouldnt start. After a while on YotaTech and trying different things it turned out that the igniter/coil went out. After I replaced it everything was good.
So after spending time under the hood looking at all of the skimpy corroded grounds I decided it was time to upgrade them. Bought some 4 gauge wire (the biggest Oreillys had) and some ends and went to work. I replaced the main alternator connection and all the grounds I could find.
  • Alternator positive to battery positive
  • Battery ground to body
  • Head to body
  • Block to body
I did notice that the engine seems to function smoother also that everything electrical seems to work better. Definitely worth it.
Next on my list is replacing all the vacuum hoses. All of them are very soft and some of them pull off very easily. I am sure that there are a few small vacuum leaks hidden in all those lines. If anyone knows what size of vacuum lines I need to buy let me know
Regency
20
Jan 3, 2020 07:43 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
DjShiznit
Jul 5, 2015 11:51 PM
Valvoman
Jun 28, 2015 02:45 PM
dirtrider0129
10
Jun 24, 2015 12:24 PM
