ChefYota4x4's 1987 4Runner Build-Up Thread
Old May 27, 2011 | 11:31 PM
  #2341
jason in tn's Avatar
Glad to see you got together man, now on to the next new /old progect I hope getting that engine goes back in smooth for ya. And then the A/C and then and then lol have a great holiday buddy I'm sure you'll be grilling or something.
Old May 28, 2011 | 04:35 AM
  #2342
mfwimg82's Avatar
chef I hate to repeat myself but you must do drop and bump stop spacers before you even move it . one revolution of axle can bind joint ruin boot and you are doing things over. I have been there and even got a tee shirt(second time I did it) feel free to pm me with any questions .
Old May 28, 2011 | 06:56 AM
  #2343
yotarob2005's Avatar
WOW Mark, moving right along here! So glad you got your front suspension done man! Looking great! Sounds like the rest of the truck will be ready and waiting on that fresh new motor. Did I miss the date you are expecying to have the motor back from the new and improved machinest? Good luck with it all bud!
Old May 28, 2011 | 08:28 AM
  #2344
ChefYota4x4's Avatar
Thanks Jason! Yeah, I would like to get back to 'DRIVING IT', for one! lol. Secondly, YES, I want AC! lol. Once it's all together, I can ask my neighbor to fix it before I head out into the 110+*F Weather in Havasu, AZ! lol. His mom is visiting, so hopefully he will find time to charge it really quick for me
I will PM ya if ya want... but I'd like to discuss it here if you would, so others can understand/chime in, etc. Not trying to doubt you, Mike....Just trying to figure it out/Understand it all; ..I thought you only did bump stop spacers when you put in low pro bump stops, w/out diff drop, then tested for binding, etc. I AM doing a Diff Drop, before it rolls anywhere. I checked the CV's several times while in full droop, stuff, etc., ....they turned very smoothly and freely(OHHHHH, ...but I didn't lock in the hubs when doing so, ..that what yo mean?). Anything you could explain on here, that'd be great, as I'm sure maybe SOMEONE might come across this and say, "Hey, I'm doing this", .... and then might need that extra info as well, ya know? I thought that took the angle off the CV's a bit, the diff drop, right? I know I've just created a space between the two arms,... just trying to understand it better, and maybe let some others who visit get there, too, ya know? Thanks, man, ...I appreciate you lookin out! ...don't want any carnage after fixing the carnage I had, lol.
Thanks, Rob!!!! You da man, ...seriously, I appreciate your understanding, buddy! This has been quite the adventure... and I'm kinda glad I got all that stuff, MONTHS ago, when I did! lol. If not, I'd likely not be able to do ANY of it at the moment. Far as the motor, .... probably mid-next week. Maybe Tues. He's probably off this weekend and Monday, soooo, lol.
Far as your CV angles, etc., ....... I know you put in 2" spacers.... What kinda mess'n didya do with the bump stops, etc.? I will read back through your thread when I have a lil more time to sit here. I remember you installing and then uninstalling the Diff Drop kit.... I'll be using it, as I often travel alone and don't wanna be stranded cuza sumpin like this, ya know? But as far as the bump stops, I'd like to discuss that here, if possible? A buddy of mine has a whole set of Energy Low Pro Stops, ...and he'll give them to me. But, if it's likely that I'll have binding, etc., maybe even carnage, .....and if I'd have to space them till they're the same as the originals, lol..... I guess I don't wanna mess with them, ya know? Any input would be GREATLY appreciated!
Old May 28, 2011 | 10:30 AM
  #2345
I also have another question;
I'm going to get it aligned since I've installed the lift, etc. But I'm wondering if something might be 'wrong'..... Because; When I look from the front of the truck, ...the driver side tire looks as if it's turning right just slightly while the pass. side tire looks straight. It might be the pass. side that's off, and not the driver side.... I'll check the pitman alignment mark and decide from there. It might also be 'toe out' on the driver side...Kinda hard to tell, so it's not dramatic if it is, but I guess I'm just wondering, ............
*** WHAT COULD BE CAUSING THIS? ***
I haven't TOTALLY torqued down the ball joint to knuckle unions yet. But I got the marks on the cam adjusters for the LCA pretty much DEAD ON... The knuckle thing might explain the "TOE OUT" stuff... but the turned inward thing,...that seems it would be more LCA adjusting cam stuffs.
*** ANY IDEAS???? ***
Old May 28, 2011 | 10:45 AM
  #2346
You changed the position the ball joints as ca bushings you pushed things back into places they haven't been for a long time. Also no weight on that front end is gonna make it sit funny. I not sure but I would think it would even affect the length of your tie rods. Just my opinion man.
Old May 28, 2011 | 11:01 AM
  #2347
Yeah, tie rods may need adjusting as well. Hmmmm! It is on the ground, btw... see in the pic above?^^ .... that's how I'm looking at it from the front, and seeing it's 'off'... (not being smartypants, btw...just sayin, lol)... I guess it would HAVE to be the ends that pull it left or right, correct? DANG, I hope I didn't bend anything! Grrr! lol. However, ..... Could it be that, since I CAN'T KNOW if it's the left or right tugged inward, ....could it be that BOTH are? lol. That would be ideal, as it would rule out BENT CRAP! lol. I did mes with the steering wheel a couple times(can't remember why, lol).... so I'm not sure I got it back to straight. Anyhow, ...........
Is this something that the alignment shop would charge me a bunch extra for?
Old May 28, 2011 | 11:04 AM
  #2348
PS> What I meant on the 't-rod ends' portion was, ... wouldn't adding all these goodies including the spacers change how things sit? Or do the lowers and rod end links stay unaffected by this mod?
Old May 28, 2011 | 11:11 AM
  #2349
I think the tie rods would be affected mark I'm no front end Guy but I'm pretty sure. Both sides would have moved and I don't think you could put enough pressure on anything to bend it. I don't think an alignment shop is gonna charge you anymore the point of what they do is to get it straight. Again my opinion.
Old May 28, 2011 | 11:12 AM
  #2350
Thanks, .... appreciated, Jason! Sorry you're working on the Holiday! Me 2! lol.
So, .... anyone else has any thoughts on posts #2344 and #2345, I'd be GRATEFUL!
Old May 28, 2011 | 11:19 AM
  #2351
No prob man hope You get some good answers,
Old May 28, 2011 | 11:25 AM
  #2352
xxxtreme22r's Avatar
Chef your being paranoid again. Yes it's off because you need to get an alignment whenever you put in the spacers because you changed the geometry slightly. This is because the center of the steering got raised and the tie rods want to pull in. Which will cause a toe in. There will also be a camber change as well. You can actually see this anytime you put the truck up on a jack where you lift both tires off the ground.
As far as the bump stops go, yes you only have to shim when your using the low profile droop stops. And it's only the droop stops (top ones) that get shimmed not the compression stops. It says that right on 4crawlers site.
Old May 28, 2011 | 11:36 AM
  #2353
That's what I was trying to say LOL
Old May 28, 2011 | 11:38 AM
  #2354
The more people say he's being paranoid the better, although I don't blame him too much. Sorry Chef been working on alot of video and having some comp problems, haven't checked into too many threads lately. I figured I had better pop my head in.
Old May 28, 2011 | 12:03 PM
  #2355
WAIT, WHO'S FOLLOWING ME?????????? hahahaha. .... Sorry, just being paranoid again! lol. Jk, jk.... I know, but I figure, 'why not make sure', ya know?
Far as the 4crawler stuff.... I saw that, ..the uppers low pro were shimmed. I understand that the bj spacer is essentially forcing the lower arm downward at a stronger angle and upper arm upward, against the T-bar pressure. New Ball joints, CA bushings, etc... I'm sure it has SOME to do with this stuff, and the book does say< "get the alignment checked" AFTER MOST of it.... I intended to... But I was just curious if something that I 'could have ' done improperly might have caused one tire to go cock eyed but the other(pass.) did not, and looks to be straight as ever.
Oh well, I'll just torque everything down to 'directions' and let'm fix it! Just gotta decide who to trust with the alignment. Firestone seems so expensive! lol. Found another guy that told me, "100$, and I'll re-do it, if needed, for the life you have it..... just bring it back if it ever goes cocked".... He does lots of Toyota stuff, used to work at TLC inc. We'll see.
Thanks, guys! Off to pick up some parts!(rear main seal, rear main seal housing gasket, couple others)
Old May 28, 2011 | 07:51 PM
  #2356
baddest94's Avatar
Hey chef good work im startn my bj spacers tomorrow evening hope it goes as good as yours they look great. And find a shop the can give you a print out of where everything is sitting. Our local shop has a meachine that is run with lasers and a computer and when they get everything in place and tightn it down the computer has a pic of four wheels and its got a reading out beside each one exm. (.001) and it will be green for good and red if they didnt get it right that way you know what they did and aint just taken someones word. Did your torsion bars give you any problems loosening or tighting them in anyway?? My driver side a can't get to turn even after spraying it with pb baster for like a week straight the passenger side turns smooth as butter.
Old May 28, 2011 | 10:21 PM
  #2357
YES, they gave me problems! I've read up a bit and learned that MANYYYYYYYYYYYYY of the bolt/to/larger nut joining's break. If you turn the top nut and the bolt turns, ...you got problems, lol. Sorry to hear that, Baddest, on the 'stuck' one! Grrr!
I did a video of some tips, ...and I'll post it asap. I think it might help ya(maybe a few more). I actually installed mine WITHOUT loosening my Torsion Bars. I'm going to have my machinist help me, as he has done a 'fix or two' on these, as he said, lol.(I guess he has a trick/special tool)....but he wont tell me, says he'd rather show me, lol.
I jacked up the upper arm with a large floor jack, reverse/stuffed the arm a lil bit off the stop, shoved a wedge in there to hold it up(Remember, I don't have A MOTOR, ...so all that weight is not there to counter the torsion bars,lol....Let's just say the A-arms went up...and so did the whole truck! lol... couldn't even get the upper arm off the stop w/out jacking up the arm>>>See, when you do that, there is resistance from the ground to arm, jack pushing up,...so it has to go up a LIL more than when you push up from the lower arm), then back and forth to the jack and the ball joint/and/spacer, wiggling and finagling until I could get a stud in the front and rear, diagonally, started those two nuts, then finagled some more, .......and then realized that THE FRIGGEN CUT OUT I MADE WASN'T ENOUGH!!!! GRRR~! LOL. I got over it and finished cutting some more and VOILA, IT FIT! (You can test the ball joint spacer in that hole where you've cut, .....but when you add the ball joint, ....WHICH IS WIDER AT POINTS THAN THE SPACER, ... you will see that you have to 'TEST' your cut with both..... And, well, remember, ....I was doing the ball joints as well! But, I'd already installed it into the knuckle, so I was 'testing the fit with my cut' with just the spacer.... that is NOT sufficient! lol)..
Don't forget to support the lower arm when you knock the studs down from the BJoint, ya know?
Old May 28, 2011 | 11:49 PM
  #2358
baddest94's Avatar
Thanks for the tips chef i hope they go good illl post pics and let everyone know
Old May 29, 2011 | 02:56 AM
  #2359
mfwimg82's Avatar
chef by looking at pics your axles are at an angle. When at full droop they may be too much, watch pass side . I have had to shim 3 ifs vehicles after bj spacers, the first one I did was my own ruined original boots on first ride . replaced axles put in drop kit ruined new bootsafter 2 weeks- replaced by napa no cost to me but added spacers on upper bump stops (not low profile) all good after that. Have done 2 other 1 pick up and one runner did drop kit and spacers from start no problems. I like no problems you can do what you think is best it is only $60 at napa to replace your axle go for it!
Old May 29, 2011 | 11:10 AM
  #2360
truckman1966's Avatar
Chef, ive always been curious on the BJ spacers for IFS. i mean, it will give you lift, but geometrically, you lose suspension travel and ride quality, don't you?
