Cali '86 RTE 4Runner rebuild...
Old 02-22-2018, 09:16 PM
  #161
Co_94_PU's Avatar
Originally Posted by TrailTrek2Fish
Ok, but do you have the P/N for the AC Cut Off? I already had the P/N for the one on the right.
sorry got my two left feet confused, give me a couple minutes. Pretty sure that jp place will have them if Toyota doesn't.
Old 02-22-2018, 09:54 PM
  #162
Co_94_PU's Avatar
I've used up all my Google-fu today, close as I can get is the prefix 89427
Old 02-22-2018, 10:17 PM
  #163
Co_94_PU's Avatar
89427-35010, discontinued
Good news is you don't need it unless your dash guage is crappy you plan on towing stuff up long hills with the AC running.
Old 02-22-2018, 10:26 PM
  #164
TrailTrek2Fish's Avatar
Well, that sucks. Thanks for finding the P/N broski. Much appreciated.
Old 02-23-2018, 07:54 PM
  #165
Slowly but surely gettin' there! I'm waiting for some more parts.
I'm just using the cheapy oil filter for the break in cycle.
Old 02-23-2018, 10:39 PM
  #166
Co_94_PU's Avatar
Sexy sexy!
A little feedback.
Heat shield for the exhaust manifold, and better tie downs for those sparkplug cables.
Clamps for the hoses to the boost regulator, if those come off "on boost" its not going to turn out well.
Do not skimp on a break in part or fluid, it is much more critical at this point than after. That said I'd have to dig out notes and research, but off the top of my head I think Napa gold is wix and wix makes the yz Toyota filters. Get the oversized filters, it might cost a little more in the filter price and an extra half quart of oil but it is good for piece of mind that you won't hit the oil pump bypass.
And questions..
Is that brass colored fitting off the turbo oil or water? If it is oil drain that's not a good angle I hope the block fitting is adjustable, of course mine is horrible so meh.
No oil cooler? I know the OEM cooler could be better but it beats nothing at all. A TC can put.out lots of heat and lots of that winds up in the oil pan.
Old 02-24-2018, 07:00 AM
  #167
C'mon bro, give your boy some credit! I did mention that I'm waiting for some more parts, right? LOL! Like I said, little by little... The only thing I'm still searching for is the P/N for the sensor I posted about on page 8 of this thread. Co_94_PU identified it as an A/C cut off sensor but we can't figure out the Toyota P/N.
The OEM heat shield fits on the LCE Turbo Billet exhaust manifold.
The brass colored fitting is a coolant passage. Below are better photos of the maze...
I'm definitely not going skimpy on the break in fluid. I'll be using Joe Gibbs Driven BR30. It's the fluid recommended by the fellas at 22REPerformance.
Old 02-24-2018, 05:02 PM
  #168
jakey poo's Avatar
That is a work of art!
Old 02-24-2018, 05:13 PM
  #169
Thanks! I'm tryin' jakey poo
I'm so anxious to receive my parts from the kingdom!
Old 02-25-2018, 02:52 PM
  #170
swerks's Avatar
will you be running a gasket between your turbo and down pipe ? just curious
Old 02-25-2018, 04:01 PM
  #171
Whats up swerks. Of course bud. It came with the LCE GT25R Kit. Theres still a lot of parts to receive and install.
Old 02-26-2018, 02:12 PM
  #172
So... I finally got the Toyota P/N (83430-96440) for the "A/C Thermoswitch," but... it's discontinued.
The sensor on the left side...
Boooo...
Old 02-26-2018, 06:41 PM
  #173
cdd408's Avatar
Nice, when you dropping it in
Old 02-26-2018, 08:59 PM
  #174
Thanks cdd408. It's TBD. Like I mentioned, there are still a lot of parts to receive and install.
Old 02-26-2018, 09:33 PM
  #175
84 yota dude's Avatar
Is that sensor broken?
Old 02-27-2018, 08:45 AM
  #176
84 yota dude... Yup, I noted what is wrong with it on my original post. Why else would I want to replace it?
The sensor on the left: The electrical connection core rotates a bit in the metal body and the sensing tip seems to be damaged because I can feel a wire tip protruding from it.
Old 02-27-2018, 12:08 PM
  #177
Duh, haha. I figured you were replacing everything at this point.
Old 02-27-2018, 04:06 PM
  #178
All good bud. I'm replacing most of the hoses, gaskets, considerably corroded parts and defective parts but not parts just because. After all, I do have a budget, LOL!
Old 02-27-2018, 04:46 PM
  #179
Haha roger that!
Old 02-27-2018, 06:26 PM
  #180
space-junk's Avatar
Is that a 22rtec only part? If not, hit up firstgen4runners on Instagram. They've helped me out on my build and have pretty decent prices.
