Billythegoat's 1992 pickup Build-Up Thread
Old Jan 10, 2012 | 04:37 PM
billythegoat's Avatar
Hello all, I finally decided to start a build-up thread after having my pickup for 2 months now. I traded my 1989 pontiac firebird trans am for it and I'm very glad I did.
Its 1992 pickup 4x4 5 spd single cab with 187K miles. It runs pretty good but it burns quite a bit of oil and smokes until its warmed up. The PO said he did a complete rebuild with machine work but he said #3 cylinder had low compression which led him to believe the rings didn't set right. It doesn't bother me that much since it stops after its warms. I plan to get another engine thats proven and dropping it and fix this engine.
About 3 weeks ago I was driving and I saw my fuel level drop way too fast and could smell raw fuel, luckily I was close to home and my little truck didnt catch on fire.
It turned out injector #3 was leaking badly which I knew had a small leak but it wasn't that bad before. I was only going to replace the orings but then I thought, why not paint the plenum and valve cover. I wanted to send the injectors to get rebuilt but they seem fine and they all ohm'd within .1 of each other
The o-ring was pretty messed up.
I got an 'injector seal kit' at nap for 2 bucks each, the old intake and fuel rail seals were pretty much rock hard
I still need to go to the dealer and see if the got the crush washers on the fuel rail
Old Jan 10, 2012 | 05:00 PM
I found a brush guard on Craigslist a few days ago and got it for $115, not sure if that's a good deal but I think it was.
I got into the painting spirit and decided I wanted to paint the wheels black along with the brush guard. I got duplicolor high performance wheel coating for the wheels and vht rollbar paint for the brush guard. I also got duplicolor engine aluminum for the plenum and valve cover. It's crazy how paint adds up
Old Jan 10, 2012 | 05:12 PM
rattlewagon's Avatar
Looks good. Welcome to the forum!
Old Jan 10, 2012 | 06:33 PM
93Xtra-Cab's Avatar
An '89 Firebird, huh? If it was a V8, then it was most likely the 305 version. Looks like you got the better end of the deal trading for the pickup! It looks to be fairly solid. I can't wait to see what it looks like after the painting is done. Definitely Subscribed. Welcome to Yotertech!
Old Jan 10, 2012 | 07:55 PM
westjohns yota's Avatar
for sure always loved these 3rd gens! just liked the 1st gens more! how i got stuck in between idk, but welcome!
Old Jan 11, 2012 | 12:47 AM
Terrys87's Avatar
When you go to put the o-rings back in, make sure and lube them up with something. I didnt and knicked one and it leaked bad. A good way to get a fire going. Welcome to the site.
Old Jan 11, 2012 | 05:38 PM
yeah it was a 305, these firebirds don't come around too often. I looked for about 6 months before I found mine and I havent seen another in decent condition since then for sale. The painting is almost done!
I'll probably use some oil
Old Jan 11, 2012 | 07:08 PM
The skid plate and lower valence were in the bed when I got the truck and needed a bit of help so I bought another 2 cans of vht. I got everything painted up and I'm very pleased with this vht stuff. The skid plate was rusted more than I thought but it still came out nice
Paint station
Old Jan 11, 2012 | 09:28 PM
RMP8080's Avatar
Painting parts, must be warm where you at. We are in the 40's here. Looks good
Old Jan 12, 2012 | 05:59 AM
knucklehead38401's Avatar
I can clean your injectors, or exchange some with you.
Old Jan 12, 2012 | 07:42 AM
Yeah its a bit warm, around 55 here but its windy. The wind made me get a few drips here and there
I'm good, thanks though
Old Jan 12, 2012 | 07:46 AM
I got the plenum and valve cover done. They came out pretty good
Jun 1, 2021 01:51 PM
crashburnoveride
Aug 28, 2015 09:20 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Nickdigg
Jul 7, 2015 06:04 AM
wilbertd
Jul 6, 2015 07:39 AM
